Microtech s5 turbo engine with a micro tech setup
Old Oct 16, 2007 | 08:04 AM
Question s5 turbo engine with a micro tech setup
Any one, I just swappped a working s5 turbo engine with a micro tech setup in to a 1st gen gle-se car and I'm having a trailing firing issue. I have checked and rechecked the wiring and all looks correct. I'm using the same coils that were in the 2nd gen car the engine was pulled from. Please any help or direction would help.
Old Oct 17, 2007 | 07:52 AM
same problem
This is driving me crazy I've now switched out the s5 crank angle sensor with an s4 crank angle sensor. I was told that this could be the possible problem. The car ran fine with the same setup in the 2nd gen car. It's got to be a wiring or micro tech setting problem. Can any one help me out or give me a number for me to call some one for help with this problem....
Old Oct 17, 2007 | 08:20 AM
Rotorhead34's Avatar
Scream baby Scream!!!
Have you tried the microtech forum on microtechefi.com?
Old Oct 17, 2007 | 08:48 AM
not yet, but I'll also try that sight thanks. I just notice that I'm not getting a quick flashing orange light on the microtech unit.
Old Oct 18, 2007 | 07:26 AM
Unhappy
Ok, no respones on microtech forum yet. I have a flashing orange light but it's not flashing as fast as if was before in the 2nd gen car. I have also tried a new crank angle sensor. still no trailing spark?
Old Oct 19, 2007 | 05:54 PM
rx72c's Avatar
Top Answer: 1
What computer is it?
Maybe your trailing coilpack/ignitor is damaged?
Old Oct 27, 2007 | 08:17 AM
Cool no power after 3000 rpm
I finally got the car running and all plugs firing. It was a grounding issue with the coil pack. My Car is running but has no power after 3000 rpm. my setup is a S5 turbo 2 street ported with 3 inch exhaust. I live at a elevation of 5000 feet above sea level. I think its a mapping issue but would like some help.
Old Oct 27, 2007 | 12:45 PM
88t2romad's Avatar
(_8(|)
could be injector staging....read the manual on it.
Old Oct 27, 2007 | 07:08 PM
rx72c's Avatar
Top Answer: 1
when you say no power?
what do you mean?
does it rev out and just go like a **** box?
or does cut it out?
has it been tuned?
have you got a wideband to see what the problem is?
have you got the leads on the right way around?
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
elfking
Aug 19, 2015 09:48 PM
morataya
Microtech
Aug 16, 2015 09:39 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
