Super AFC Area is for discussing the Apexi Super AFC
Super AFC Ok, so I have some questions.
Old Oct 14, 2007 | 08:56 PM
Asterisk's Avatar
iRussian
I'm in the process of buying a T2 swapped S4. The previous owner did the swap, rebuild, 5 lug conversion, and upgraded the electronics system with a SAFC, 255lph walbro, 680cc secondary injectors, along with a ported wastegate and a boost contoller, running 11psi.
He monitored it with a SAFC AEMwide band MAF and a boost gauge.
Since then, the SAFC and MAF are off the car, and have been sold. I'm a little tight on money right now, but planning on buying an SAFC and wideband really soon.
However, I'm not quite shure on how to use it, so are there any guides out there?
Old Oct 14, 2007 | 11:48 PM
misterstyx69's Avatar
Retired Moderator, RIP
I found this..I don't know if it will help,but here it is. http://fc3spro.com/TECH/MODS/EL/FUELCON/APEXI/afc.htm Good luck,STYX.
Old Oct 15, 2007 | 06:33 AM
RotaMan99's Avatar
Here is a wiring manual I put together
http://www.midnightgray.net/docs/safcwiring.pdf
Its pretty simple to use, I want to put together the user manual from scanned pages but I havn't had time.
Ill get back to you on that one. Ihave to go fix a buddies car right now.
Old Oct 15, 2007 | 04:37 PM
Asterisk's Avatar
iRussian
Alright. Thank you so far.
Old Oct 20, 2007 | 09:19 AM
RotaMan99's Avatar
He monitored it with a AEMwide band MAF and a boost gauge.
There is one thing wrong here. There is no such thing is a AEM wideband MAF (Mass Air Flow Sensor). You must be talking about a wideband O2 which tells you your AFR. A MAF only tells the ECU how much air volume is flowing into the engine.
We don't have a MAF, we only have a Flapper AFM which can only measure airflow and not air volume.
I hope to have time to scan in the user's manual for the SAFC2 this weekend.
Coochas
44
Nov 5, 2019 11:08 PM
sccarally
South RX-7 Forum
Oct 8, 2015 05:27 PM
Xepez
2nd Generation Non-Technical and pictures
Sep 22, 2015 03:15 AM
