13b pizza pie
Old Oct 11, 2007 | 06:42 PM
knivesm's Avatar
13b pizza pie
Does anyone have a guide that shows how to make a 20b out 0f 3 13b's????
Old Oct 11, 2007 | 06:55 PM
BLK FC3S's Avatar
C088
die
Old Oct 11, 2007 | 06:58 PM
knivesm's Avatar
what does that mean????????
Old Oct 11, 2007 | 07:06 PM
FirstRotaryExp's Avatar
The Brap is Back
it means to search harder....say in the 20b forum?
Old Oct 11, 2007 | 07:25 PM
knivesm's Avatar
i did. i cant find anything.
Old Oct 12, 2007 | 12:02 AM
R.P.M.'s Avatar
Likes to swear....alot
BAHAHAHA....are you kidding? There is no such thing.
Just buy a 20B, don't waste your time by trying to make 13B parts into a 20B. But if your "very serious" about doing something like that....then go ahead and try. I'd give you a couple weeks to realize the cost of proper machining to do such a thing before you give up.
Old Oct 12, 2007 | 12:55 AM
bcool's Avatar
Rest In Peace Dave
Here i have the guide for it:
Old Oct 12, 2007 | 12:59 AM
JSmith0101's Avatar
Play Well
I was struck by the most interesting thought yesterday, I'm only an e-shaft from a 3 rotor build.
That is all.
Old Oct 12, 2007 | 03:23 AM
Evil Aviator's Avatar
Rotorhead
Option 1: Buy a 20B "thick" side housing ($2600 new) and a 20B eccentric shaft ($3300 new), combine that with the required 13B rotors, housings, oil pump, etc., and fabricate or buy a 20B oil pan and intake manifolds.
Option 2: Sell the 13B engines and buy a good used 20B-REW engine with turbos for $4,500.
Regardless of the above, you will still spend another $5,000 to $25,000 on the remainder of the conversion, depending on the level of performance desired.
Old Oct 12, 2007 | 07:09 AM
RETed's Avatar
By the time to get all the pieces, you could've bought a used JDM 20B...hell, you could've bought the whole front clip off a JC3S Cosmo.
Hell, I think you could by TWO 20B's at this point.
This is why you can't find too much info.
The folks who are SERIOUS about this know what the **** they are doing and don't ask an Internet forum how do do this.
HINT: GURU Racing
-Ted
Old Oct 13, 2007 | 02:59 PM
hwnd's Avatar
watashi no shichi
I think the TS has a point.
I dont use the front 20b front case, housings or rotors.
I'm using the thick iron shaft... thats about it (from the 20b). Didn't break the bank doing it. I think that if you buy the parts, you'll see how things line up & what mods you'll need to take.
LongDuck
Oct 7, 2015 08:12 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
Robrods64
Oct 2, 2015 07:56 PM
Boans
V-8 Powered RX-7's
Sep 25, 2015 04:34 PM
