Power FC power fc , wire cut?
You should have gotten instructions with the PFC that shows you which ones to cut. If you don't cut them, the ecu will switch back and forth between two idle settings hunting for the correct one causing the rpms to bounce when the engine is warm. Annoying, but it won't hurt anything. If you can't find the instructions let me know and I'll dig mine out for you.
It's never fast enough...
Yes, PLEASE dig them out. I need to check mine as well. Then again....if you simply disconnect the AWS, then it won't hunt for idle
I think I might just end up removing the pins from the PFC. There is a vendor, which I have heard, that completly removes the pins from the PFC. Afterall, if the PFC doesnt need those wires, then it probably never will.........right?
Trending Topics
Flybye, XS is the one who removes them for you. There's one problem. Open up the ecu and look at the boards. You can't reach the second row of pins. You need to pull/cut them from the outside which isn't the easiest thing to do. I tried, but it turned out the little nubs that were left were still making a connection, so I ended up going back and cutting the wires.
I believe SR Motorsports cuts/pulls the pins as well.
FYI...
16-pin connector
3J blue-green EGR SW (Calif)
26-pin connector
4F black-red SPLIT AIR BYPASS SOL VALVE
4O blue-yellow EGR SOL VALVE
4P brown-yellow AWS SOL VALVE
FYI...
16-pin connector
26-pin connector
streetlegal?
Mar 17, 2022 02:46 PM
The Shaolin
Sep 14, 2015 07:50 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
