Safe to run(T2)...
Old Apr 8, 2002 | 12:01 PM
Ryde _Or_Die's Avatar
Safe to run(T2)...
A FCD & s-afc with full intake and exhaust? I know I've asked alot of T2 questions but want to be positive about not blowing my engine. Thanks.
Old Apr 8, 2002 | 12:13 PM
rx7_turbo2's Avatar
Professor D.P
Yes that's safe to run, but more info is needed. How much boost?
Old Apr 8, 2002 | 12:14 PM
I actually don't know. I mean the boost will be uncontrolled until I get the wastegate ported and a boost controller. I want to keep it at or under 10psi though.
Old Apr 8, 2002 | 12:17 PM
Josepi's Avatar
Despise Enmity
Keep the stock airbox on. That'll help to keep the turbo down.
Old Apr 8, 2002 | 12:21 PM
Hmm, thats the only mod I have done so far, an intake. Should I send my turbo and wastegate in to get upgraded and ported already? Man I have some money to spend but am having trouble deciding what to get and when.
Old Apr 8, 2002 | 12:31 PM
Josepi's Avatar
Despise Enmity
Well when you get an exhaust and guages, put the stock airbox back on. That way, when you do put on the exhaust, you don't spike and kill the motor. Gently ease up on the pressure.
If that money is really eating a whole in your pocket, make sure you have everything you need to sustain the other upgrades. IE Fuel->exhaust...
Old Apr 8, 2002 | 12:34 PM
Ya my plan was to get some 720cc injectors, s-afc, fcd and some gauges. Then get a dp/mp. Then get a walbro fuel pump. Then get the turbo upgraded and wastegate ported. Then get a boost controller. And that would be about it for power mods for a while.
Old Apr 8, 2002 | 01:31 PM
rx7_turbo2's Avatar
Professor D.P
720 injectors
Fuel Pump
SAFC
Is what I will be using to run my hybrid turbo. Remember a boost contoler can NOT lower boost, only raise it.
Old Apr 8, 2002 | 01:35 PM
RETed's Avatar
Upgrade fuel pump?
-Ted
Old Apr 8, 2002 | 01:44 PM
rx7_turbo2's Avatar
Professor D.P
I will be using an FD pump.
Old Apr 8, 2002 | 01:46 PM
720 injectors
Fuel Pump
SAFC
Ya thats why I want to get my wastegate ported when I get the turbo upgraded. And where are you getting the 720cc injectors? You are putting those in the secondaries correct? Are they a direct fit? Thanks alot.
Old Apr 8, 2002 | 01:52 PM
rx7_turbo2's Avatar
Professor D.P
I am getting the 720's from a friend. Lots of places offer direct replacment injectors. Yes i am putting them in the secondary fuel rail. I am however thinking of making the primaries a bit bigger as well.
Old Apr 8, 2002 | 02:09 PM
Well are these "top-feed" ones direct replacement?
http://www.rx7.com/cgi-local/2catalog.cgi?cat=12&part=6
Old Apr 8, 2002 | 02:15 PM
rx7_turbo2's Avatar
Professor D.P
I would assume so. You might want to send them an email to find out whether those are high or low impedance.
Jun 26, 2016 10:21 AM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
20B Forum
Aug 19, 2015 01:47 PM
Wolf_
Aug 11, 2015 04:23 PM
