T04R 87 TII dyno results
Old Sep 20, 2007 | 07:08 PM
13bturbofc's Avatar
mmm doritos
Talking T04R 87 TII dyno results
i dynoed my 87TII today and was very pleased with the results i couldnt get my alky injection system to work so i didnt go above 15 psi.. my mods are..
brand new S5 stock port motor
HKS T04R 62.1 .84
greddy FMIC
greddy cast manifold
greddy 47mm WG
profec b boost control
at 10psi i put down 337whp and at 14 i put down 380whp we could have hit 400 but it was a conservitive tune and we couldnt get the wg to hold 15 for some reason its only a 7psi spring and its pretty old...ill post the dyno sheets as sone as i can get to a scanner.
Old Sep 20, 2007 | 07:16 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
how responsive is the 62-1 with the .84 on stock ports? i run a cosmo re sock port (larger intake, smaller exhausts respecitivly) with a 60-1 with a .84 and even with my 5lb spring im spooled by 3k and holding 5lbs by 3500-3800 (wastegate starts to open almost immidelty, no controler running right off the spring)
runing my 1.0 housing spool's by 3500 with 10lbs by 4k, would had have higher however was all it was tuned for
Old Sep 20, 2007 | 08:54 PM
88rxn/a's Avatar
tom port.. AKA streetport
im sorta close to you and need a tuner next summer....who tuned your car and where at???
nice #'S BTW!!
Old Sep 20, 2007 | 10:32 PM
FrankV702's Avatar
Damn! nice numbers man.. I still have yet to get my car running good enough to slap it on a dyno..
Old Sep 20, 2007 | 11:53 PM
Insomniac21772's Avatar
Congratulations, finally shes back on the road.
Old Sep 21, 2007 | 06:54 AM
13bturbofc's Avatar
mmm doritos
yeah its been a long time comin i was hopeing to have it dynoed back in may but i ran into issues
Old Sep 21, 2007 | 07:00 AM
13bturbofc's Avatar
mmm doritos
it has barely ANY lag it spools real fast and come's on HARD...theres hardly any first gear at all...lol im running the profec B and it has a set gain option that makes it spool faster but we didnt even turn it up cause it would just roast the tires in any gear so we kept it down..its puttin down around 320 tourqe so its a challenge keepin it hooked
Old Sep 21, 2007 | 07:16 AM
HAI-TEK7's Avatar
I dont get it? U list T04R 62.1??
Doesnt the T04R use 66.7mm inducer, while the 62-1 uses a 62mm? Glad to hear the .84 turbine housing spools nice, thats what my turbo has.
Anyways sweet numbers! you need to swing by the house, i need MOTIVATION
Did KDR do the tuning?
Old Sep 21, 2007 | 07:21 AM
13bturbofc's Avatar
mmm doritos
ill have to double check the 62-1 thing...and yeah KDR did the tuning we tuned for like 3 hours and he charged me for 1 hour..dave is a really cool guy he has helped me out alot..i deffinetly will stop by your place again and let you check it out..i need to buy a new FPR i think mine is taking a ****
Old Sep 23, 2007 | 02:02 AM
FD3S_wanted's Avatar
1+
Old Sep 23, 2007 | 02:35 PM
13bturbofc's Avatar
mmm doritos
i cant remeber what the size is exactly i bought it used from a forum member
Old Sep 25, 2007 | 08:29 PM
13bturbofc's Avatar
mmm doritos
i cant wait to get the alky workin and see how it pulls then
Old Sep 28, 2007 | 12:19 AM
hurleysurf24's Avatar
wtf rotary wtf
you said you had a profec b spec 2 ... i dont quite understand the gain setting . where do you have yours set at ? miens around 42 and im hitting full boost around 3900 psi on stock turbo? i dont know where to set it lol
Old Oct 8, 2007 | 06:56 AM
13bturbofc's Avatar
mmm doritos
its kinda hard to explain but if you read the instructions they explain it pretty well
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
FC_DREAMS
Sep 9, 2015 06:24 PM
