Microtech Is there a difference between the 13B-RE air temp sensor and S5 13B-T sensor?
Old Sep 18, 2007 | 04:51 PM
MaczPayne's Avatar
Mac Attack
I've tried several sensors, and they were all the same, they read negative, which means that their resistance values did not match what the LT8-s was programmed for.
Now, the person that had this EMS before me said that it was programmed for a 13B-RE. Question is, are their air temp sensors different than the S5 TII's?
My temp ign and fuel maps are zeroed out because of this problem, and I'm hesitant to boost the car when it's cold out. Any help is greatly appreciated.
Old Sep 19, 2007 | 07:00 AM
Johny zoom's Avatar
Not to hijack
What about the REW temp sender? I have been running 13b-T Im in the process of running a REW and need to know if the temp sender will work.
And macz This temp sendor was recommened on the Microtech forum.
http://store.summitracing.com/partde...0&autoview=sku
Old Sep 19, 2007 | 08:36 AM
MaczPayne's Avatar
Mac Attack
Holy ****, that sensor was what I was looking at yesterday.
How certain are you that this sensor will work?
Old Sep 19, 2007 | 01:29 PM
Johny zoom's Avatar
It came from this thread. http://www.microtechefi.com/forum/vi...ir+temp+sensor So I dont know personally
Now are the s-4 13b-T and the 13b- rew temp sensor interchanageable?
Old Sep 19, 2007 | 01:53 PM
MaczPayne's Avatar
Mac Attack
I looked at mazdatrix to look at the difference between the 13B-REW and 13B-T sensor, and found that they are not the same size. I don't know the resistance values, so I can't help you on that one.
Now a few questions:
What are the resistance values of the 13B-T air temp sensor?
The MSD sensor is 50 - 100k ohms.
Old Sep 20, 2007 | 08:25 AM
Johny zoom's Avatar
Ok Macz my problem is solved. The threads are the same so Ill just swap mine out.
I looked at the fsm didn't find you answer
Maybe you should try the microtech forums?
Good luck
Johny
Old Sep 20, 2007 | 11:21 PM
boosted1205's Avatar
You cannot interchange 13BREW and 13BT air temp and water temp sensors.
These 2 must be used with whatever the MT was programmed for.
The 13B Cosmo and 13BT are interchangeable.
If you check the resistance on REW and BT, they are very different.
I'm sure Dale , rx72c or maybe Aaron will chime in.
Old Sep 21, 2007 | 12:51 PM
MaczPayne's Avatar
Mac Attack
Thanks for replying, boosted1205.
To recap:
The 13B-RE and 13B-T air temp sensors are interchangable, so in other words, they are the same and have the same resistance values correct?
The 13B-REW sensor is NOT the same as the 13B-RE.
My LT8-s was programmed for a 13B-RE, so that rules out the FD sensor since the unit was not programmed for it.
And because my 13B-RE programmed LT8-s is reading my stock 13B-T sensor in the wrong range, maybe it was programmed for an aftermarket sensor.
The whole motif for this thread was to find out whether I needed a 13B-RE sensor or an aftermarket sensor. And if the 13B-RE sensor is in fact, the same as the 13B-T, I have found my answer. I'll have to purchase an aftermarket sensor.
I'm looking at the MSD air temp sensor, but I am not sure if it will work. The resistance values must match the values the Microtech was programmed with.
Old Sep 22, 2007 | 05:20 PM
rx72c's Avatar
Top Answer: 1
Last i checked. the plugs are different but the resistance values are the same. but i could be wrong.
Microtech
30
Apr 23, 2016 06:37 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
succesfulljoe
Aug 20, 2015 08:59 AM
