Flywheels... how light is too light?
Old Sep 13, 2007 | 05:56 PM
davemo's Avatar
clutch artist
i want a lighter flywheel for my STREET driven 2nd gen...i intend to buy the 17 pound steel one, but im wondering if the aluminum is worth the extra $100. the difference is probably negligible off the track i'd assume. the stock flywheel weighs in the range of 25 pounds, correct?
http://www.mazdatrix.com/flywheel.htm
Old Sep 13, 2007 | 05:58 PM
Mechanic's Avatar
THE Mazdabator
i heard you wouldnt want alumi for streets, but i got it but i havent driven it yet. i cant give you note on that. light steel feels pretty good from another seven i drove. almost like stock but pickup is a little nicer. by nicer i mean seems to rev a little faster. nothing much more than that, i wouldnt say it gives you better speed to a sense that you can notice it.
Old Sep 13, 2007 | 06:06 PM
davemo's Avatar
clutch artist
im just wondering if the aluminum will casual shifts a female dog because i dont wanna have to shift from 3rd to 4th at 35mph at light speed because my rpms drop so quickly, i know it'd be great for shifting at 6400rpm
Old Sep 13, 2007 | 06:19 PM
phoenix7's Avatar
ummm what? i read female dog and got super lost. My friend drives his NA with Aluminum fly and doesn't seen to have a problem.
Old Sep 13, 2007 | 06:25 PM
HOZZMANRX7's Avatar
Driving RX7's since 1979
If you never have to deal with stop and go driving, Aluminum is ok. Otherwise, stay with lightened steel. Less flywheel weight, more slip clutching needed to keep from stalling the engine from a dead start. Been there, done that. I'm a lighten steel guy as a result.
Old Sep 13, 2007 | 08:54 PM
rxtuner79's Avatar
I have a Fidanza 8 lb. on my '89 NA, and I am extremely happy with it. If you have a turbo, it might be better to stick with a heavier one because of something to do with losing less boost between shifts or something like that. If you do have a turbo, then hopefully someone else can clarify that for you.
If not, like I said I love my flywheel, and I don't think I could ever drive another car without one. It revs a lot faster and I think it also frees up about 10-12 horsepower at the wheels. It's not anywhere near as hard to drive as everyone makes it out to be, and now that I have driven this one I will probably be disappointed if I ever bought a heavier one. You have to either shift somewhat fast or give it a little gas in between shifts, because it does drop faster. You don't have to slam gears though. It's a great buy, and I say go for it!
Oh yeah, and stop and go traffic also isn't as bad as people say it is (just my opinion).
Old Sep 13, 2007 | 09:03 PM
Michael Knight's Avatar
Don't hassle the Hoff!
Zero lbs. is to light!
Old Sep 13, 2007 | 09:09 PM
Funkspectrum's Avatar
I run a 9lb chromoly flywheel and it's great
Old Sep 14, 2007 | 01:41 PM
davemo's Avatar
clutch artist
thanks... by female dog i meant a word which im not sure i can use heh heh. but how much faster do the rpms fall with the aluminum vs. stock or light steel? let's say a shift from 3rd to 4th at 35 mph, i do this all the time driving through a town. i dont have my car so idk how much the rpms drop in that shift but it's definitely less than 1000. will i have to shift super fast to ensure they don't drop below where i need them for 4th gear? you know, perhaps 35 in 3rd @ 2500 to 35 in 4th @ 1750rpm
and how much do those stock flywheels weigh ?
plus if anyone could give radii for the stock and aftermarket we could figure out exactly the differences between them
1/2*mass*radius squared = rotational inertia of a disk
Old Sep 14, 2007 | 02:11 PM
Spectator's Avatar
I run an 8 pounds Cusco flywheel on my DD and its great. Absolutly no problems.
Old Sep 14, 2007 | 02:55 PM
Sideways7's Avatar
Just say bitch and get it over with. Its much less confusing, and no one cares.
As for the question, a lightened steel flywheel is probably best of regular street use. I have an aluminum flywheel and love it, but it can be a bitch in traffic.
Old Sep 14, 2007 | 03:33 PM
Spectator's Avatar
The clutch can be a bitch in traffic, not the flywheel.
Well, not with my 8 pound one. How is it a Bitch S7?
Old Sep 14, 2007 | 05:24 PM
Ottoman's Avatar
always modding
I don't see the problem...
I got a Racing beat Alum. with a Spec clutch on my TII
i love the superlight revs it gives.. just blip the throttle and the rpm dances..
I can't imagine what it would be like with lightened and balanced internals and a good port..
unless your into Drag racing on the strip... where inertia of the F/W helps
go with the lightest one u can
Old Sep 14, 2007 | 05:33 PM
Carzy Driver's Avatar
Law Breaker
for your NA go with the lighter steel flywheel
Old Sep 14, 2007 | 05:44 PM
coxxoc's Avatar
Shooting for 500
I have a 9 pound flywheel. Going from stock to this was noticable, but nothing you can't work with. Give it a little more RPM before engaging the clutch. Now the engine revs like a bike.
The clutch/pressure plate is what gives people hell. Mine definately presented a learning curve.
Old Sep 14, 2007 | 05:59 PM
Sideways7's Avatar
I dunno, maybe its the fact that I really hate stop and go traffic. It just seems like I have to slip it a little more than in other manuals I drive. For all I know its just the difference in weight and gearing, since I've only driven it with this flywheel. Honestly, its really not that bad, but theres not much point in getting a aluminum flywheel for a street driven car. If you auto-x it or something then sure, spring for it, but otherwise you will still get good benefits from just the lightened steel one.
rgordon1979
40
Mar 15, 2022 12:04 PM
JoesFC
Oct 5, 2015 08:10 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
