FD Eibach Pro Kit vs. Tein S. Tech
Old Sep 11, 2007 | 09:15 AM
D4rw1n's Avatar
Jason
Are the Eibachs worth the $100 more they cost on eBay? Or are they pretty much even and you are just paying for the name? I will be installing them on stock touring shocks that will see some track and drag use as well as being a daily driver.
Old Sep 11, 2007 | 09:33 AM
Mahjik's Avatar
Mr. Links
IMO, do not use the Tein S-Tech with stock shocks. They are a much higher spring rate than the stock or Eibach springs. Tein S-Tech's will lower the car a lot more than the Eibach (hence the need for a higher spring rate). Eibach's are a mild drop, but it does drop the front lower than the rear.
Old Sep 11, 2007 | 04:17 PM
ArmenMAxx's Avatar
i have Tein S-techs with my r1 shocks. Works very well but the ride is pretty harsh. As far as performance wise, i think the teins are better because of their higher spring rate yet they wont work well with the touring or base shocks. I have heard that Tein makes cheap stuff compared to other companies.....
Old Oct 8, 2007 | 08:14 PM
CarzArKoo1's Avatar
tein s tech are stiff
Old Oct 10, 2007 | 12:58 PM
Pat McGroin's Avatar
Sushi ******!
Edit- Double Post
Old Oct 10, 2007 | 12:59 PM
Sushi ******!
Please get the eibachs. Yes, they are worth the extra 100 bucks.
Old Oct 10, 2007 | 04:38 PM
BlouZbee's Avatar
Eibachs on stock shocks vs. Stock
Old Oct 10, 2007 | 05:05 PM
dgeesaman's Avatar
I just got a set of lightly used Pro-Kits for $155 shipped off of eBay. How much are you seeing them for?
Dave
Old Oct 10, 2007 | 05:50 PM
fdeeznutz's Avatar
White is tight
BlouZbee your car doesn't even look lowered.
Mine with Eibach stock struts. FYI, the front is very low. I get tire rub over large bumps.
Old Oct 10, 2007 | 07:52 PM
BlouZbee's Avatar
it doesnt look like a lowered car but they give it a better stance. i replaced all 4 strut mounts at the same time so the ride quality actually improved with the eibachs.
maybe someday ill a get konis to go with them but im in no hurry. i quite pleased. ive experienced no rubbing.
Old Oct 10, 2007 | 08:58 PM
Qball's Avatar
Comp Yellow Mica
i went from eibach's to S-tech's because they go lower. no difference in ride quality for me. im on tokicos also.
Old Oct 13, 2007 | 10:42 PM
t-von's Avatar
Rotor Head Extreme
You know your opinion goes completely against Howard Coleman's ( the suspension expert) recommendation? He claims the Tien S Tech are a perfect match with the stock shocks.
Old Oct 13, 2007 | 11:16 PM
Mahjik's Avatar
Mr. Links
I've been viewing Howard's posts for a long time and I haven't seen him recommend the Tein's with stock shocks. He does recommend the Eibach's with stock stocks; but I still believe the Tein S-Techs are too high of a spring rate for the stock shocks. It's extremely doubtful that Mazda envisioned the shocks supporting spring rates double of what the stock spring rates are....
Old Oct 13, 2007 | 11:43 PM
v8huntr's Avatar
i have eibach on my car and today i went through automatic car wash and it didn't rub at all.
rgordon1979
40
Mar 15, 2022 12:04 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
