how good i a t70
Old Sep 10, 2007 | 06:46 PM
turbo876port's Avatar
rotorhead
how good i a t70
how good i a t70 on a big port motor i currently have a t3/ t4 50-63 a/r's the t70 is 70-84a/r's how well will this t70 work on my block?
Old Sep 10, 2007 | 08:54 PM
hondahater's Avatar
spending too much money..
well the .84 should make it spool faster. there are a few people on here that are using the t70 with good sucess including someone that ran it on a half bridge at 19 psi and made 490rwhp however he had a 1.15 hotside. Do some searches. I'm running a mpt70 and am still putting the car together so I don't have any numbers for you but have done a ton and a half searches on t70's.
Old Sep 10, 2007 | 09:22 PM
rotorhead
well
i am doing the research its just alot of turbos to go thru i dont want to spend a fortune i just think that my hybrid is maxing out at top end i think the efficiency is like 55% i am pretty sure the t70 has like a 70% effeciency and it will flow more volume.i just want to know if the t70 will make a huge difference?
Old Sep 10, 2007 | 10:12 PM
hondahater's Avatar
lol, take a look at a t70 compressor map. The efficiency range is huuuuuuge. it will be a night and day differance between the two turbos.
Old Sep 10, 2007 | 11:34 PM
rotorhead
well
i have often heard that people shouldnt use a t3 flange type for rotary i guess it doesnt flow enough exhaust volume what do you all think?
Old Sep 11, 2007 | 01:33 AM
ZAN_TUNING's Avatar
Just turn up the boost!
step up and go T4
Azevedo
26
Mar 1, 2019 09:19 PM
