Confused with wheel sizing.
Old Sep 10, 2007 | 06:24 PM
celbii's Avatar
jackie chan > chuck norri
Im getting confused with these numbers, I need to buy a new set of wheels and I was looking at these for my s4 vert.
Offset: 40mm Bolt Pattern: 5-114
Rec. Tire Size:215/45-17
Lightweight: 20.6lbs.
Can anyone tell me if these will fit on my S4 vert? Im having troubles using the FAQ numbers.
Old Sep 10, 2007 | 06:35 PM
Brody8877's Avatar
#FakeCarEnthusaist
http://www.fc3spro.com/TECH/MODS/RT/rims.htm
Old Sep 10, 2007 | 07:39 PM
nvrdone's Avatar
if you have coilovers. Stock gxl wheels are 15x7 +40. the extra 1/2in will prolly make them rub. Not 100% sure though.
Old Sep 10, 2007 | 07:45 PM
celbii's Avatar
Yeah I was worried about that problem also. I guess I will keep looking for smaller ones.
Old Sep 10, 2007 | 08:15 PM
djmtsu's Avatar
DGRRX
Stock GXL wheels are 15x6. I have S4 and S5's to prove it.
Old Sep 10, 2007 | 10:07 PM
jazzmanbob's Avatar
Rotate or go home!
Those will fit no problem on any stock 7. My vert came with 6.5" wide wheels with 205 section tires. Your chosen tire size is a 215 section. That is only 10 millimeter wider than my stock tires. That is 5 millimeter wider from the tire centerline to each side. Nothing to worry about. Your chosen wheel size is 1 inch wider than my stock wheels. So it will sit 1/2" closer to your strut and stick out 1/2" closer to the wheel opening. Again not an issue. For the back wheels there is a lot more room to play with. I have calculated that an 8", 35 mm offset wheel fitted with 225-45-17 for the front and 245-40-17 for the rear are close to the maximum sizes for stock suspension. If you have lowered your suspension then you should be running camber adjusters to properly set up your driving dynamics. By doing that you are also by default improving your tire to suspension clearances.
Bob
Old Sep 11, 2007 | 10:58 AM
nvrdone's Avatar
Then I have gtu wheels. My bad.
Old Sep 11, 2007 | 11:01 AM
MaczPayne's Avatar
Mac Attack
No such thing as a stock 15x7 wheel.
Old Sep 11, 2007 | 11:58 AM
freemanrx7's Avatar
^Hold On
I ran 17/225/50 on my 88 gxl with DTSS. Fills the gap nicely and never rubbed.
Old Sep 11, 2007 | 12:22 PM
Black91n/a's Avatar
20.6lb 17x7.5's are far from being light. Those are heavy wheels and the handling and acceleration will suffer. If you can get lighter wheels.
Old Sep 11, 2007 | 12:24 PM
dw89s5's Avatar
i know nothing
the 215/45/r17 will fit without rubbing on a s5 that is lowered 1.5 inches
i used to run them it worked fine
Old Sep 11, 2007 | 07:41 PM
djmtsu's Avatar
DGRRX
****, 225/45/17's fit up front, and 255/45/17's fit out back, no rubbing.
Some guys are using wider than that with just simple fender rolling.
Old Sep 11, 2007 | 09:04 PM
Black91n/a's Avatar
^ Yea, but with lower offsets. My 17x8's with 225/45/17's were pretty close to my stock suspension and are pretty close to the coilovers, and I've got a 30mm offset.
Old Sep 12, 2007 | 10:29 AM
celbii's Avatar
Would this bolt patteren fit on my vert?
http://www.discounttiredirect.com/di...100&vid=006201
Old Sep 12, 2007 | 10:40 AM
djmtsu's Avatar
DGRRX
Yes, but they are dual dilled. I am not a fan of dual drilled wheels. Don't know why.
FYI- Those are the same size as the stock wheels. You need to make sure they will clear the factory calipers. Also, your stock BBS wheels probably weigh ALOT less.
rx7jocke
72
Jun 17, 2016 03:48 AM
dillrx7
Sep 7, 2015 09:38 AM
