Microtech tach reading
Old Sep 10, 2007 | 08:33 AM
Rotorhead34's Avatar
Scream baby Scream!!!
tach reading
I realize my tach is reading half the rpms being turned because I have only one trailing coil hooked up to the tach wire. What would happen if I hooked both neg's of the trailing coils to the tach? Will the coils begin firing each other or what. I have 4 individual coils.
Old Sep 10, 2007 | 09:58 AM
MaczPayne's Avatar
Mac Attack
You haven't changed anything to the tach wiring have you?
Make sure the spark trigger is set to +maz.
Old Sep 10, 2007 | 10:31 AM
No, I haven't changed any wiring. Are you saying to hook up the tach wire from the Microtech to the tach wire in the dash?
Old Sep 10, 2007 | 02:40 PM
MaczPayne's Avatar
Mac Attack
No, wire it up as if it were stock out of the factory. The microtech has nothing to do with the tach on your dash.
Make sure the pos spark trigger on the microtech is set to +maz. I forget what screen it is off the top of my head, but scroll through them and you should get to the right screen.
I didn't touch the wiring for my tach, and just left it as it were, out of the factory.
I had the same problem you had, found out that my pos spark trigger wasn't +maz, but something else. I changed it, and it works now. Give it a try.
Old Sep 10, 2007 | 02:54 PM
Yeah, but using the stock coils correct. I have 4 individual coils. I am using the stock tach and stock tach wire. Also, this is a first gen. And yes the spark trigger is set to +maz
Old Sep 10, 2007 | 04:19 PM
MaczPayne's Avatar
Mac Attack
Yeah, stock coils. I had also forgotten that you have a 1st gen.
rgordon1979
40
Mar 15, 2022 12:04 PM
newtgomez
Sep 13, 2015 07:39 PM
