Unknown Leak Passenger Side. Please Help!!!
Old Sep 8, 2007 | 05:24 PM
DaMaCCa's Avatar
Hey I've had a leak on my car for a little while now on the passenger side. I've had the cover off on the bottom of my car and can't seem to locate where it's coming from. The leak I'm assuming is oil because no other fluids seem to be going down, is dripping onto my passenger side control arm and also the undercarrage cover on that side. Doesn't seem to be that fast of a leak or else I'm sure I would have found it by now, but it keeps everything pretty coated in oil :-/. If anybody can help that'd be awesome. I'll come back with some pics of what it's leaking onto tommorow after it stops raining and drys up a little bit.
Old Sep 9, 2007 | 10:25 AM
Aaron Cake's Avatar
Engine, Not Motor
The only exposed oil lines in that are on the metering oil pump.
Fully degrease the engine, and then go for a short low speed drive. You should be able to see oil starting to seep out from somewhere.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
