Defined Autoworks Race prep, Dyno tuning, Rotary Performance, Unique Fabrication and Transplants
noobie question about my gsl
Old Sep 7, 2007 | 07:25 AM
MR.TUCKER's Avatar
ok so i get out of my car lock the door close it then i noticed the damn door unlocks every time i shut it... any advice on what causes this?? and what do i have to do to fix it ?
Old Sep 7, 2007 | 07:30 PM
GtoRx7's Avatar
Collections Hold
First post, and in this section, welcome to Rx7club! Your issue is not a problem at all, in fact it is what mazda had designed into all the Rx-7's. When you lock the door, and before you shut it, lift up on the outside handle and shut the door at the same time. This will keep the lock, well, locked. Hope that helps!
Old Sep 8, 2007 | 12:40 PM
jE5s3's Avatar
Talking hey
great thanks it worked hahaha again thanks
Old Sep 8, 2007 | 12:53 PM
EricRyan's Avatar
Autocrossed. I got CONED!
Why the hell would you post in this section? Haha
Old Sep 9, 2007 | 05:10 AM
jE5s3's Avatar
Question lmao
good point hahahah ****
Old Sep 19, 2007 | 11:45 AM
shm21284's Avatar
Fabrineer
It's so you don't lock the keys in the car. Holding the handle is merely a "trick" to lock it without using the keys.
EDIT: EricRyan is right, this should be in a generation specific forum. But you asked the right guy, nonetheless.
_Tones_
May 25, 2021 05:37 AM
1987 T2
11
Apr 1, 2017 11:59 PM
Nosferatu
Sep 5, 2015 02:13 PM
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
