1991 fc stereo
Old Sep 6, 2007 | 07:28 PM
Trueno102's Avatar
1991 fc stereo
well im trying to change my stereo sysytem
when i bought the car it had no stereo so i bought a sony xplode stereo but for some reason when i put the volume up to 20 or higher it turns off i don't know why could it be the stock amplifiers because their only 15watts
the speakers on the doors are kickers but you can hardly hear anything from them.
the stock speakers on the dashboard and you could hear those but the sound goes to your feet and you can't really hear them.
the rear speakers are alpine but they don't sound good anymore
a friend i know works as a car elecronics
and told me to get better sound quality from a car like this would be to rewire everything
and he's selling me kickers all 4 speakers with 2 tweeters for $135
Old Sep 6, 2007 | 07:40 PM
Flash's Avatar
re-amemiya body vert
Well, looks like you've answered your own question. Every time I've installed new speakers/deck in an FC I've removed the stock amps and run new wires. Never had a problem.
Old Sep 6, 2007 | 07:41 PM
Flash's Avatar
Edit: double post.
Old Sep 6, 2007 | 08:31 PM
Trueno102's Avatar
So should i rewire or just remove the stock amplifiers and buy a new amplifier
i mean is it really necessary to rewire
Old Sep 7, 2007 | 01:21 AM
Trueno102's Avatar
so is it simple to remove the stock amps
Old Sep 7, 2007 | 02:41 PM
Flash's Avatar
Yeah it's easy. Running new wire is also easy. On a difficulty scale of 10 it is a 1. If you can change oil you can take out old amplifiers and run new wire.
Running your highs and mid range speakers (not a sub) directly to a modern deck will give better sound that with stock amplifiers in my experience. If I remember correctly, the front two speakers go to one amplifier under the dash. If you know how to use a screw-driver, you can remove it. The rear speakers should have one for each speaker. Again, use a screw driver and set yourself free.
I don't know what your goals are, your capability or your current system is so I'm telling you what I can. You can always go for the ultimate and get crossovers to separate the frequencies, have a separate amp for lows and highs and another for subs ( if you want subs). Bottom line is the stock amps are useless in 2007.
Old Sep 14, 2007 | 10:28 PM
rxmclaren7's Avatar
Blazin' 87 N/A
what size are the door speakers??? i looked but i am too lazy to look any further...lol
AlexRX7fc
Apr 22, 2018 09:35 AM
TeamRuffRacing
Sep 30, 2015 08:13 PM
betes
Sep 27, 2015 08:25 AM
