Questions about SE.
Old Apr 6, 2002 | 01:03 PM
JacobFC's Avatar
Question Questions about SE.
Did the what equiptment was standard on the SE? Am I correct in asuming that it was the lightest model FC? Did it get the standard 4.10 gears or was it lower?
Old Apr 6, 2002 | 01:08 PM
redstreak's Avatar
Well I have an '86 SE and as far as I know it isn't anything special, P/S, no A/C or power door locks or windows... etc. No rear wiper. As for the transmission as far as I know all 2nd gen transmissions are the same with the exception of the TII.
Old Apr 6, 2002 | 01:32 PM
JacobFC's Avatar
The tranny is the same, but I remember reading that the ring and pinion on the "four lug" models is a 3.90 or something.
Old Apr 6, 2002 | 01:39 PM
vaughnc's Avatar
knowledge junkie
The GTU-S was the lighest 2nd gen rx-7.
Old Apr 6, 2002 | 01:44 PM
stickgoat's Avatar
AE whore nomore
It's ligher than GXL, yes. What options do you have? Less options = less weight.
The brakes on the 4-lug models aren't as powerful as on the 5-lug, but a conversion can always be done if you wish to look into that sort of thing.
Basically though, engine/tranny are the same, and yes, you'll be lighter than most other models with more options. The main difference I believe is the 4-lug wheels.
Old Apr 6, 2002 | 01:54 PM
FC3AZ's Avatar
so.........4-lugs have 3.90's in the rear? Interesting...........that might end up to be an advantage at the strip in some sort of weird way. hahaa
Old Apr 7, 2002 | 12:13 AM
redstreak's Avatar
hey I didn't know that the 4 lug had 3.90 in the rear. Interesting, you learn something new every day. What do the other models have?
Old Apr 7, 2002 | 01:41 AM
Icemark's Avatar
JacobFC is wrong.
Unless you had an auto tranny, the rear end was 4.1 on all SE models. Brakes were single piston on 4 lug hubs all around with solid disc in the rear.
Only the automatic cars and 88 and 91 verts had the 3.9 rear ends.
Old Apr 7, 2002 | 01:49 AM
FC3AZ's Avatar
yay! 4.10's for me!!!!!! on my 87 SE that is.......
Old Apr 7, 2002 | 03:06 AM
Mazdarules's Avatar
The base model from 1986-88 is lighter than a GTUs
Old Apr 7, 2002 | 02:04 PM
JacobFC's Avatar
Oh, cool. So the SE does have 4.10s! I was worried that I would have to swap the rear end if I got one. I'm not so worried about the brakes. The four piston brakes are nice, but I found that the smaller brakes have a better pedal. The small brakes give up sooner, tho.
Thanks for the info everybody!
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
