new guages
Old Apr 6, 2002 | 10:20 AM
presetlimits's Avatar
new guages
im about to get an air-fuel ratio guage and most likely an oil pressure guage. i was wondering how difficult and what exactly you connect these too.
Old Apr 6, 2002 | 10:24 AM
RETed's Avatar
AFR gauge taps into the stock O2 sensor wire.
The oil pressure gauge is a bit trickier, as it needs to be in direct contact with the oil flow.&nbsp A Racing Beat adapter plate is added costs, but it makes connecting an oil pressure sensor (and oil temp sensor) a breeze...
-Ted
Old Apr 6, 2002 | 11:06 AM
how about a water temp gauge..what does that hook up to or ran to?
Old Apr 6, 2002 | 12:44 PM
RETed's Avatar
Water temp gauge...mechanical would need a fitting and hose into somewhere into the coolant flow.&nbsp For an electronic gauge, you'll need to tap the sender into the coolant flow.&nbsp I like to drill and tap close to the thermostat housing, since this is supposed to be one of the hottest areas of coolant flow...
-Ted
gabescanlon
Sep 5, 2015 12:09 AM
