2nd Gen fitment 18'wheels / rims
Old Sep 1, 2007 | 04:00 PM
gtcar2's Avatar
Wheel experts:
will these rims fit a 91' convertible?
Bolt pattern : 5 x 114.3
Size : 18 x 8.5(front) & 18 x 9.5(rear)
Offset : 32mm(front) & 35mm(rear)
if not how can you fix ?
Old Sep 1, 2007 | 04:52 PM
Spectator's Avatar
Usually you use spacers to fit wheels that dont. But these are so freakin large that they'll over shoot the fenders. So I'll go with a classic Ted answer and say:
No.
Old Sep 1, 2007 | 05:11 PM
K.ronic's Avatar
My Mom thinks I'm special
I have 18" 8.5's all the way around with a 40 series tire and they fit just fine. They have never rubbed even under very hard cornering. However, it should be noted that I'm running KYB AGX (2 in front and 6 on the rear) with Eibach proset springs (.8" drop I think), a Racing Beat front sway bar and RB HD adjustible end links. You will sacrifice some ride quality though. I have a set of 16's with a 50 series tire and the ride was much smoother, but it was to low (kept dragging my presilencer across mild speed bumps).
Old Sep 1, 2007 | 05:21 PM
jazzmanbob's Avatar
Rotate or go home!
Check out the attached.
The front wheels at 32 mm offset will bring the tire wheel assembly 17 mm closer to your spring. Measure the space available now that will tell you if they fit. As for the fender clearance 33 mm closer to the fender should not pose a problem. I must say you will probably have to run 8 mm spacers in the front. That will definitely bring your wheel out too far.
Old Sep 1, 2007 | 06:22 PM
SayNoToPistons's Avatar
Insane Burning Diarrhea
18's will look terrible on most FCs in my opinion. My friend had trouble fitting 18 x 8 in front so he just ditched it and ran 17s instead.
Old Sep 1, 2007 | 07:27 PM
K.ronic's Avatar
Does this look terrible to you?
Old Sep 1, 2007 | 07:42 PM
Most*
Old Sep 1, 2007 | 07:45 PM
K.ronic's Avatar
LOL! All right then.
Old Sep 1, 2007 | 07:55 PM
Hyper4mance2k's Avatar
The Shadetree Project
http://fc3spro.com/TECH/MODS/RT/rims.htm
Old Sep 2, 2007 | 02:25 AM
Spectator's Avatar
It does to me.
Unless you wanna PIMP UP YOUR RIDE!!
Old Sep 2, 2007 | 03:26 PM
K.ronic's Avatar
Originally Posted by F.C.3S
It does to me.
No one asked you......***.
Old Sep 3, 2007 | 10:58 AM
unicorn_squad's Avatar
you guys are ******* retarded.
the rears will fit fine.
the fronts will fit with a small spacer... ~5-7m should work, depending on your suspension. and you may need to roll the fender depending on what size tire you try and run. I would probably stick with 225/40, and you should probably be fine without rolling them.
Old Sep 3, 2007 | 11:01 AM
K.ronic's Avatar
I have no spacers at all and the fenders aren't rolled. No rubbing anywhere, under any condition.
Old Sep 3, 2007 | 11:06 AM
owen is fat's Avatar
Originally Posted by gtcar2
Wheel experts:
they wil fit perfectly.
run the lowest profile possible to keep the tire O.D. as short as possible.
235 front and 255 rear willk fit very nicely.
I had 17x8 and 17x9 both +35 before I went widebody and it fit superrrrrnice.
Old Sep 3, 2007 | 11:22 AM
Wezzmo's Avatar
fitment can also depend on what suspenison you are running..
with my cusco coilovers, i couldnt run 17x8 +35.. +30 was about the highest i could go, and it had very minimal clearance...
you *may* need to run a small slip on spacer on the front..
Old Sep 9, 2007 | 02:56 PM
gtcar2's Avatar
Thanx for all the positive input. I will apply the good advice and show the results in pictures.
