Coolant Temp Sending Unit Questions
Old Apr 6, 2002 | 12:03 AM
rico05's Avatar
WTB S5 N/A FC
I don't seem to have one!! My 91 n/a does not have a unit above the spark plugs!!! Both holes are empty, but my stock gauge seems to be working. I have an aftermarket one in the mail, and I have no clue where the sending unit for it is!!!!! Help!!
Old Apr 6, 2002 | 12:29 AM
Scott 89t2's Avatar
SOLD THE RX-7!
the holes you are looking at are probably the knock sensor holes?? it's under the oil filter. it's pretty small. the oil pressure one is bigger and right above it.
Old Apr 6, 2002 | 12:37 AM
rico05's Avatar
WTB S5 N/A FC
I was looking in the Hayne's Manual, and the holes it showed for the location of the sender are empty. So, I need to know where it is on my 91 n/a!!
Old Apr 6, 2002 | 08:23 AM
RETed's Avatar
You're close, but no cigar.&nbsp The water temp sensor for the intrument cluster is closer to the oil pressure sensor.&nbsp The sensor is really small, and I think it has a yellow wire going to it.
-Ted
Old Apr 6, 2002 | 10:03 AM
Wankel7's Avatar
Haven't we ALL heard this
Dude, if there is nothing in the hole small woodland creatures would be following you around for that sweet tasting coolant because it would go every where!
It is small and has a blade coming out of it
James
Old Oct 12, 2024 | 11:34 PM
divinefist81's Avatar
CA
so ur saying the coolant temp sending unit switch which is WHITE connector is under the oil filter and not by the water pump?
Microtech
30
Apr 23, 2016 06:37 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
