wierd idle problem revised
Old Apr 5, 2002 | 10:17 PM
spik 87 trubo 2's Avatar
yea the car when i first start it will stall if i dont hold the gas down and keep it above 1k but as soon as it warms up it idles fine just at 2k well almost fine it has a slite put put sound to it and when i rev it past 6k it will start to poure out wite smoke out of the exaust there is also a smell of gas when i get in the car i had the sunroof open to try to vent it out but it didint seem to help any it just comes back i think it might be an exaust leak but i did a quick check of the cat and mid pipe and didint find any thing unusaual plus when i got the car the previous owner said he had just replaced the bac with a junk yard part so if he wasnt lying that rules that out but any help would be much appprecated and aurk thanks for the advice and it didint sound like you were a jerk thanx
Old Apr 5, 2002 | 11:47 PM
Amur_'s Avatar
Refined Valley Dude
I'll be a jerk now when I tell you that using periods from time to time can be a good thing.
How long have you had the car?
Smell of fuel - start at the fuel pump and work your way forward to the engine. Check all the connections and clamps to make sure that each is solid and tight. If it's even a little loose, tighten or replace it. Two summers ago one of the rubber fuel lines just plain *fell off* it's connection to the top of the pump.
Your fuel injectors may also be leaking. And you may also consider installing a fuel cut-off switc if you're smelling the gas BEFORE you start the car. Do searches here for both these ideas - they come up often as topics here.
Shitty idles are most frequently the result of vacuum leaks. You're driving a 15 year old car and chances are the vac lines are factory originals. If you read some of the posts from other users who have gone after vac lines, you'll see that sometimes the lines were so brittle they shattered in the guys' hands. Also, check your TPS.
Are you losing coolant at all? White smoke *could* be burning coolant, which means a seal has failed in the engine and the engine will be garbage soon. If not, and you're revving it while the engine is cold (which you should NOT do, ever - you're kicking your engine in the *** when you do that) then I would think that the 'white smoke' is mostly steam, just like you'd get from any other car in winter... Check these:
https://www.rx7club.com/forum/showth...ht=white+smoke
And especially this:
https://www.rx7club.com/forum/showth...lue+smoke+link
Checking the BAC is easy - do a search.
ttyl,
Amur_
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
ZacMan
Sep 19, 2015 09:20 PM
firzen
Sep 15, 2015 12:04 PM
rx7shirley
Sep 2, 2015 02:11 PM
