what to do to make 10" wheels fit front fc with 30 mm front fender
Old Aug 27, 2007 | 05:15 PM
boost_its_what_for_dinner's Avatar
RotoriousRx7
all i can think of is the spring and or the lower control arm with wheels all the way turnd?
thx let me know
Old Aug 27, 2007 | 08:13 PM
Wezzmo's Avatar
low offset and it will fit...
there is a drifter on here with 18x10s on standard guards... look in the fc wheel fitment thread..
i have 18x10 +19 which i will try and squeeze under my stock fc guards too, but i dont think i would be able to drift on them.. my 17x9 +12s are real close already to my sway bar, etc on full lock with the supernow spacers
Old Aug 28, 2007 | 12:25 AM
RETed's Avatar
I'd try to shoot for 10.0", +0.
That should easily clear the stock suspension with almost any reasonable tire size.
You might be able to drop the offset down to +5...even down to +10.
With coilovers that give you added clearance, add another +10 on the offset.
-Ted
Old Aug 28, 2007 | 08:33 AM
RotoriousRx7
but i dont think the fno1r's come that low???
Old Aug 28, 2007 | 05:19 PM
RotoriousRx7
the lowest they come is +12 so a 10/12mm spacer with 30mm fenders should work then?
Old Aug 28, 2007 | 10:24 PM
owen is fat's Avatar
+12 will barely fit with certain coilovers and certain offsets.
I used spacers on my 17x10 +12 to clear and the effective offset was close to +5.
this year I run closer to a +10 and it fits nicely.
with just the right combination of coilover and tire setup and spring perch height you can fit a 10" wheel with a +12 offset.
Old Aug 29, 2007 | 08:32 AM
RotoriousRx7
what suspension you running
Old Aug 29, 2007 | 06:26 PM
tein flex.
the spring and perch is right where the tire wants to be... if I ran springs 2" shorter then they would be farther up and away from the tire, gving me an extra maybe half inch of clearance but I like the rates and springs and can work with it the way they are.
