How much gas do you guys race with???
Old Apr 5, 2002 | 03:41 PM
Decay's Avatar
Question How much gas do you guys race with???
I'm talking on the strip...
I know there are SERIOUS issues of hitting boost when you are low on fuel, BUT there are some damn good advantages of weight reduction of racing with say, a 1/4 tank or less...
What do you guys think? Leave as much as a half tank in or what??? Thanks...
Old Apr 5, 2002 | 05:36 PM
SleepR1's Avatar
I wouldn't run anything less than 1/2 tank road racing or drag racing...
Old Apr 5, 2002 | 05:41 PM
RX7FAN's Avatar
Weight savings not worth it
I ran out of fuel because of sloshing gas while running 1/4 tank autocrossing, blew 2 runs doing this, went and put 6 more gallons in and problem was gone.
Jim IN PA
Old Apr 5, 2002 | 05:53 PM
jmseven's Avatar
Asset is Wealth
When dragging....under 1/4....way under.
Old Apr 5, 2002 | 05:57 PM
purepsi's Avatar
1/4 of a tank, weight reduction is always a plus
Old Apr 5, 2002 | 05:59 PM
HUGH's Avatar
Seven Spears of Shizugata
no less than a 1/4 tank. Reason Hey I need traction, plus no fuel when gas sloshes to rear of tank under extreme load = lean running engine = Rebuild.
Old Apr 5, 2002 | 07:52 PM
redrotorR1's Avatar
LS6 Convert
i dunno if any of you have ever looked at the insides of an FD fuel tank ... it's a little, well, strange.
there's a baffle on the inside that runs all the way around ... forming like a box on the interior. i didn't look close enough to notice if it all drains back to the center, but i know it does become important during auto-x and possibly road racing. sometimes, the severe changes in direction will slosh fuel over the baffle, and lower the available fuel ... bad if you're running below a quarter tank. (as mentioned in RX7FAN's post) ... weird design.
Old Apr 6, 2002 | 12:10 AM
Pumped's Avatar
i always use a bit more than 1/4 tank
Old Apr 6, 2002 | 10:59 AM
the_saint's Avatar
For autocross I can't run with less than 1/2 tank or I get fuel starvation in hard left sweeping left hand corners.
thesaint
Old Apr 6, 2002 | 11:33 AM
Toadman's Avatar
Nomad Mod
gasoline = 6 lbs a gallon
Old Apr 12, 2002 | 04:37 AM
evot23's Avatar
Classy
A quarter of a tank gives you about 5 gallons of fuel. More than enough for autocross and and definitely enough for drag....my experience anyway.
Eddie
Old Apr 12, 2002 | 10:03 AM
MaxRX7's Avatar
hambre y sueño
whatever is in there unless it is close to empty.
Old Apr 12, 2002 | 10:47 AM
95R2-89TII Ground Zero's Avatar
Banned
That's about what I run on the strip. Just over a 1/4 tank.
Tylerx7fb
39
May 27, 2019 12:45 PM
Clacor
Aug 14, 2015 09:17 AM
