Possible detonation, but not sure how
Old Apr 5, 2002 | 01:42 PM
OPEC's Avatar
Okay here is the scenario, I have had this problem on and off for a little while now. Under 3/4 or full throttle I am hearing what I am to assume is detonation. I really only hear it in 4th gear, everyonce in awhile in 3rd. I will be cruising in 4th at about 3000-3300 rpm and then punch it. I started getting in the habit of doing this for tuning purposes so I could lessen the notice of the transition from primaries to secondaries. I know that if i really wanted to get the car up and moving, I should shift to 3rd, but even then it will happen sometimes. I have never heard it the noise, which sounds like something metal hitting together, above say 5500 rpm or so. It always seems to happen between 3800-4500 rpm, which is about the time or shortly there after the turbo has hit full boost 12psi. It doesn't seem to matter if it is cold outside or hot. I never see anymore than 10.5 lamda on the wideband when it is happening. I have had it tuned out leaner 11.2 or so and never heard a thing. The EGT temps never get above 670 Celcius when I hear it.
The first time it happened, I thought that I had gotten some bad gas, I always use 93 Octane and only buy the same brand of gas. So I put some octane booster in and new gas and the problem seemed to go away. But it has come and gone a few times since then, during about a 4 month period. The car never feels like it stumbles or looses power when it happens. I back off the throttle immediately. Other than that the car runs awesome, the only other things is that sometimes I will get a stumble around 5500-6000 rpm this will happen in 2nd, sometimes 3rd., but this is never associated with the noise and has been happening basically ever since I put the new engine in the car a year ago. So i am pretty sure that they are not related.
The car is in the same basic state of tune as when I dyno'ed the car. the boost is the same the fuel map is the same, maybe minor, and I mean minor adjustments have been done. If anything right now, I have the car running richer across the board, low and high throttle. The car hold an awesome idle dead on 750-780 rpm, and pulls 15-17psi of vacuum. Same amount of vacuum it has since the engine first ran. Here are a list of concerened mods and parts.
full 3" exhaust
stock turbo 12psi
4 720cc injectors. less than a year old
Apex SAFC (they are tuning the injectors way down)
HKS Front Mount
Mazdacomp 3" radiator
Manual boost controller
Paul Stokes FCD
4 NGK Platinum BUR9EQ plugs (less than 4000 miles)
I think that is the list of the concerened mods, I may be leaving out something small though. I am stumped on this one.
Old Apr 5, 2002 | 04:10 PM
RETed's Avatar
Re: Possible detonation, but not sure how
Where is the EGT probe mounted?
Just by the EGT numbers, you're running overly rich.&nbsp What you could be hearing is a rich misfire - try and back down the fuel even more.&nbsp What's your settings on the S-AFC?
-Ted
Old Apr 5, 2002 | 05:32 PM
OPEC's Avatar
Re: Re: Possible detonation, but not sure how
-Ted
The EGT probe is mounted about 2" from the turbo on the DP, that is the exact same place where I have the sensor for the wideband tapped in. Here are the settings for the SAFC
Throttle Points
LO 20% HI 60%
LO rpm x 1000
1 2 3 4 5 6 7 8
-17% -3% +2% +2% +2% +2% +2% +2%
HI rpm x 1000
1 2 3 4 5 6 7 8
0% -6% 0% +8% -11% -16% -21% -14%
I hope this helps. If you need more info Ted let me know.. Thanks man
Old Apr 6, 2002 | 08:50 AM
RETed's Avatar
WOT, shoot for 780C EGT temps.
Are you using the stock fuel pressure regulator?
Do you have an upgrade fuel pump in your car?
-Ted
Old Apr 6, 2002 | 08:54 AM
OPEC's Avatar
-Ted
Yeah.. I do have a stock regulator, but I have a walbro fuel pump in the car. If I take the car full throttle all the way through 4th gear, it will get pretty close to 780. But I have never heard the noise when i am really close to redline, only around 4500 rpm or so, when the EGT are much lower
Old Apr 6, 2002 | 08:56 AM
RETed's Avatar
Is that a +8% at 3kRPM?&nbsp Try leaning that out back to "0" or going negative...
-Ted
Old Apr 6, 2002 | 08:59 AM
OPEC's Avatar
-Ted
it is actually +8 at 4k rpm.. sorry about it being hard to read, I tried to format it some, but it was lost when i posted it. I will give that a shot if you think that i should lower it at 4k also
Old Apr 6, 2002 | 09:03 AM
RETed's Avatar
You'll need to "linearize" the adjustment points...
No need to format them, I know how the S-AFC operates, so you can just dump the raw numbers left to right.
Remember, the rotary revs so fast, that you'll need to look at adjustments a bit earlier than you're having at a certain RPM band.&nbsp The +8% looks a little suspicious.&nbsp I run almost the same set-up as you with 4x720's, but I use a Field SFC-HyperR for fuel adjustment.
-Ted
Old Apr 6, 2002 | 09:08 AM
OPEC's Avatar
-Ted
Thanks man.. I will give this a shot and let you know what happens. Thanks for some insight. Off to tune, back soon
Old Apr 6, 2002 | 10:12 AM
RETed's Avatar
Yeah, it makes more sense that the +8% is actually at 4kRPM rather than 3kRPM...
-Ted
Old Apr 6, 2002 | 11:17 AM
OPEC's Avatar
Okay back from adjusting the maps a bit. Here are the new settings
Throttle Points
LO 20% HI 60%
LO rpm x 1000
1 -17%
2 +4%
3 +4%
4 +4%
5 +2%
6 +2%
7 +2%
8 +2%
HI rpm x 1000
1 0%
2 -7%
3 -7%
4 -7%
5 -8%
6 -15%
7 -21%
8 -14%
Here is what happens now. I am not hearing anything in 3rd gear at all, and the whole time I was out I never had that bog happen at around 5500rpm or so like I was talking about, so that is good.
However I am still hearing the same noise in 4th gear, right at about 3800-4000 rpm or so. This is just shortly after I am hitting full boost. I am getting the same amount of boost in 3rd and 4th 12psi. I had the problem of the car going really lean at this point when I had 550cc injectors in the primaries. That is why I put the 720cc injectors in and that problem was cleared up. EGT's under WOT look dead on 780C. If I am in 4th above 4000rpm and I go WOT, no noise. I have also never heard it doing 2nd-4th WOT pulls. At this point I am completely stumped as to what could be the cause of it just happening in 4th.
The car pulls a lot harder now with the new HI map settings. I do have a under the hood manual boost controller that is tucked in between the turbo and the shock tower of the engine compartment. I am almost starting to wonder if that much sudden air flow going to the turbo is flexing the lines going to the controller and it is moving and tapping something metal. I don't think this is the case, cause I am pretty sure that I have it zip tied pretty well. But I am going to check that.
Old Apr 6, 2002 | 12:24 PM
snoopster76's Avatar
Twisted Girl Chaser
hey i don't have a metal sound, but just about 6000 rpms at full 11-12psi boost the car acts like someone plugged my intake.
Old Apr 6, 2002 | 12:31 PM
RETed's Avatar
3800 is the magic number for the fuel injector crossover.&nbsp It sounds like you might have grounding problems...
Try this for now...jack down the 3, 4, 5 positions -2% at a time, and see if the sound changes.&nbsp If it ges LOUDER, readjust back to the original settings - this confirms it's leaning due to the fuel injector crossover.&nbsp If the sound starts to disappear, jack those ranges another -2% and run again...if the sound lessens, then it's still rich misfiring in the midranges.&nbsp The car likes to run about -5% leaner from 3kRPM to 5kRPM, so you might be still too rich in the middle...
-Ted
Old Apr 6, 2002 | 01:22 PM
OPEC's Avatar
-Ted
I will give that a shot and let you know what happens. I think that you might be right on with it being to rich still, cause as soon as I go WOT all I see are 10.0 on the wideband for about what seems like a second.
Old Apr 6, 2002 | 06:07 PM
OPEC's Avatar
Well I wasn't able to test it a whole lot, but I did take away fuel from 3000-5000 rpm like you said, and I still heard it. I can't say if it was louder or not seemed about the same. So I richened it up just a bit in the 3000-4000 rpm range and did a couple runs and it didn't happen, and I got quite excited. I did one or two more test runs and it came back. I think that I have the fuel adjusted much better cause I did notice this time that wideband measured about 11.2 for just a split second right at about 4000 rpm and that is when I noticed the sound.
I didn't get another chance to adjust stuff cause I was almost out of gas and was on my way home from the office. It would seem that I am not able to get enough fuel for that split second. I could try and richen it up a bit more in the 3000-4000 range. In order to see if I am maybe running out of the ability to feed the car more fuel I could try and hold the car at about 3500 rpm and richen the mixture up and see if I a change on the wideband. The only problem that I could see in that is that I wouldn't be under boost and I wouldn't be under the HI map.
If you have anymore ideas, let me know. I think that we are getting much closer.
Old Apr 6, 2002 | 07:18 PM
RETed's Avatar
I really think it's the 3800RPM hesitation you're trying to tune out.&nbsp Check here for detailed info...
http://fc3s-pro.com/TECH/FAQ/3800.htm
Adding grounds would be the easiest way to fix this...
-Ted
Th0m4s
Feb 26, 2019 02:04 AM
Howard Coleman
The Good Businesses
Sep 15, 2015 10:31 AM
msilvia
15
Sep 11, 2015 12:13 PM
A-Spec
Mar 15, 2002 03:52 AM
