How Much Octane Fuel can a FD take?
Old Apr 5, 2002 | 12:42 PM
Type RZ's Avatar
Im going to head up the local drag strip and i was thinking of buy like a gallon of like 114 octane fuel, i was wondering how high of an octane fuel can a FD motor take??
Old Apr 5, 2002 | 12:44 PM
Lost Time's Avatar
Chimera Driver
Stay away from the leaded stuff. Aside from that, knock yourself out.
Old Apr 5, 2002 | 12:53 PM
CYM TKT's Avatar
hey, your car is on fire!
cant you run leaded pretty safely if you have a heated o2 sensor?
Old Apr 5, 2002 | 01:05 PM
martini's Avatar
leaded will kill your cat as well as your O2.
Old Apr 5, 2002 | 01:08 PM
Lost Time's Avatar
Chimera Driver
What martini said. Do a search on "leaded fuel" if you want to know more.
Old Apr 5, 2002 | 03:12 PM
JONSKI's Avatar
5yr member, joined 2001
I common misconception is that higher octane fuel increases performance on it's own. The only reason for higher octane is to prevent preignition (a.k.a. knocking or pinging) when using aggressive ignition timing and very high boost. Use toluene if you're that concerned.
-Jon
Old Apr 5, 2002 | 05:33 PM
SleepR1's Avatar
I've run Elf 114 unleaded, and it doesn't work well with my FD. I've found anywhere between 100 to 110 unleaded works well, but 114 seems to stifle the motor...
I run the high octane for road racing events to prevent pre-ignition, not for performance...although, there must be some performance benefit...it certainly "feels" faster with unleaded 104 (Sunoco) or 110 (CAM 2?)...
Old Apr 5, 2002 | 06:51 PM
VTECthis's Avatar
Apexsealistically Chalngd
Thats a great misconception, using race gas, or very high octane fuel with no added boost or advance timing gives you less hp, the fuel burns slower, and is less reactive, this is why it prevents pinging, it combusts less easily. You use race gas to run more boost or timing or both, otherwise, it gives no or less performance than regular gas. The lower the octane, the more volitile it is, if you could run 15psi on 89 octane, youd make more power than at 116 octane.
Rob
Old Apr 5, 2002 | 08:16 PM
SleepR1's Avatar
Hmmm....then I'm saving my motor from pre-ignition!
Old Apr 6, 2002 | 05:36 PM
Type RZ's Avatar
so how high should i go with unleaded fuel??
rgordon1979
40
Mar 15, 2022 12:04 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
