apex seals????
Old Aug 24, 2007 | 06:23 PM
Toyotarx7's Avatar
Question apex seals????
quick question??? how do you when ur apex seals are broken ??? like what signs would the car/engine show or do to symbolize they're broken
Old Aug 24, 2007 | 06:50 PM
supraturbo1987's Avatar
Run like crap...idle poorly...get a compression check....works every time
Old Aug 24, 2007 | 07:53 PM
Sprockett's Avatar
Former Rotorhead
engine shaking, boost gauge needle moving at idle, no power...that kinda stuff
Old Aug 24, 2007 | 08:04 PM
RotaryEvolution's Avatar
Sharp Claws
ever seen a paint can shaker? a rotary idles much like that when the seals go out on a rotor, as well your vacuum gauge pulses very rapidly.
Old Aug 24, 2007 | 08:22 PM
rexhvn's Avatar
Rotary for life!
+1
Old Aug 24, 2007 | 09:57 PM
Toyotarx7's Avatar
is there any early signs i the i can catch before they go? my idle right now is very shitty, it idles at 4k.....yes 4k, and its cuz of my vacumm lines, and when u sit in the car u can feel vibrations, could that be my seals or becuz of my vacumm lines?
thanks for the help by the way
Old Aug 24, 2007 | 11:09 PM
iceblue's Avatar
Passing life by
Well it sure can't help get the leaks fixed it causes you to run lean. The only sign to tell that they are weakening is a compression check.
Snook
Oct 8, 2015 10:09 PM
