How do you tell if you have a bad alternator?
Old Apr 5, 2002 | 10:56 AM
TainoIndian's Avatar
what do you do to diagnose the alternator......or to tell if it is bad never had a bad one so i dont know what to look for.
Old Apr 5, 2002 | 11:00 AM
Rated R1's Avatar
Oji San
Start the car and disconnect the negative battery cable. If the car still runs your alternator is OK. What makes you think the alternator is bad?
Old Apr 5, 2002 | 11:22 AM
purepsi's Avatar
i had the battery checked at autozone and checkers, they said the battery was good so i replaced the alternator, no more dying car.
Old Apr 5, 2002 | 01:25 PM
my car died on me
some one said could be bad alternator??? i was at light it just died??? no reason i didnt stall or anything
Old Apr 5, 2002 | 01:46 PM
7-sins's Avatar
thats not paint....
I think if your alternator was bad you would see your lights start to flicker ect. Stalling out can be a bunch of problems but you still might want to do Rated R1's test, never hurts to check.
Old Apr 5, 2002 | 02:09 PM
purepsi's Avatar
7-sins is right, if it has something to do with the electrical system (battery, alternator) the ligts should dime and the car should dye sorry for not stating that earlier
Old Apr 5, 2002 | 02:20 PM
Lost Time's Avatar
Chimera Driver
Does anyone know a good way to tell if the alternator is on its way out? Not dead completely, but you know, on its last legs.
Old Apr 5, 2002 | 03:00 PM
exactly what lost time says i wanna know if you can tell if its on its way out when i hit brakes lights interior dim a bit cant really notice but it does dim and also when i have radio up loud
Old Apr 5, 2002 | 03:08 PM
rynberg's Avatar
Go to PepBoys or similar and have them check your alternator. They will do it for free.
Old Apr 5, 2002 | 03:19 PM
Lost Time's Avatar
Chimera Driver
rynberg, what are they checking? Is it just output of the alternator?
Old Apr 7, 2002 | 12:08 PM
ZoomZoom's Avatar
SEMI-PRO
NTB will check the whole system while its running with a computer diagnosic. 10 bucks and it tests Battery, Alternator, Voltage regulator, starter etc. Gives you a print out and will show if your alternator has any burned out diodes. Most have 3 diodes and if 1 or 2 die the alternator will work but will put out much less AMPerage. Have it checked on a computer diagnostic. 10 bucks is cheaper than just replaceing 200 dollar alternator or a 70 dollar battery.
Old Apr 7, 2002 | 03:58 PM
rynberg's Avatar
Sorry, who is NTB?
Old Apr 7, 2002 | 07:04 PM
Lost Time's Avatar
Chimera Driver
National Tire and Battery, NTB.
Old Apr 7, 2002 | 09:26 PM
technonovice's Avatar
Jinx
The altenator warning lamp should illuminate when it goes bad. Misfiring can happen.
Isn't there a way to measure output with a multimeter?
Make sure your battery terminals are clean too.
Old Apr 7, 2002 | 10:51 PM
ZoomZoom's Avatar
SEMI-PRO
Yeah NTB. Thier computer will test the system under Load. Thats how you can determine how much power its producing and it will give a read out.
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
