New to water injection please help
Old Aug 21, 2007 | 11:20 PM
nlsolja123's Avatar
I currently have a 86 rx-7 that has been swapped to a s5 t2 by "MWAH".
I currently have a full 3 1/2 exhaust from the turbo back that was on the donor car, also the turbo looks slightly larger than a factory but im unsure, I have installed a hks Bov and have a front mount that will be connected soon im in need of the Greddy compression tube b4 it gets hoked up.
i idle at around 800 and 15-18 vaccumn, I have hit around 14 psi on my Autometer boost gauge without a boost controller.
I dont know if my car has been ported bu i've had people tell me it has is. Also i dont know if i have a chip in the factory ecu. I only hit around 5 psi in 1st .
Ok Now to my question im considering getting A water/meth injection kit and installing it when my FMIC is put on. Will i need tuning for this or can i just plug and play. I planned on letting it start spraying at about 5 psi.
is there anything i can do to tel if i have a ported engine or if my turbo is stock? number casting on the turbo? Open the ecu for a chip?
Old Aug 22, 2007 | 07:32 AM
coolingmist's Avatar
The only way you will know if your engine is ported is by asking who ever owned it before you. typically ported engines will pull less vacuum at idle, but thats from from conclusive.
Tuning always yields the most power gains, however you will have a nice safety buffer if you run methanol/water injection.
We are in Georga (Norcross), I notice you are in georgia, feel free to stop by our shop if you are close.
www.coolingmist.com
CM
Old Aug 23, 2007 | 12:57 AM
Turblown's Avatar
Turn up the boost
You're heading towards a blown engine. Find your local rotary shop before you go into positive pressure again...
Rotary Performance Parts
Old Aug 23, 2007 | 01:13 AM
ZAN_TUNING's Avatar
Just turn up the boost!
exactly what he said! holy hell you're probably on stock injectors and everything running 14psi??? it's called boost creep
water injection is the last thing you need to worry about right now
Old Aug 24, 2007 | 01:28 AM
nlsolja123's Avatar
well i've had the car for about a year and been driving it fine.
I always run 93 octane or 100 when i go to the airport
Old Aug 31, 2007 | 12:24 AM
radkins's Avatar
Don't use aviation fuel. It is not made to run in cars and you will actually loose quite a bit of power using it.
Logan Reinisch
44
Sep 17, 2018 12:20 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
