Strange lighting problem
Old Apr 4, 2002 | 11:09 PM
tmak26b's Avatar
Okay guys, here is the deal. Today my interior light started to act up. While I was inside BK taking a dump, when i came back out. I started the car and turned on the lights. I noticed the interior lights dont light up as bright as it should. After i rev it a few times, it ran away. Then I drove a block across the street to get gas. This time the light dont even turn at all after i start it. I drove like that for 15 min until it light up again. Drove home with no problem. Just a few minutes ago, i went down to turn on hte parking light. It seems to light up real little, then a few sec later it would light up fully. What do you guys think it is, my headlight switch going to crap to bed?
Old Apr 4, 2002 | 11:15 PM
Sniper_X's Avatar
Ill refrain from mentioning the obvious tendancy tward making fecal references, but its probably a loose connection at the battery, or that one wire and bolt at the top of your alternator.
You might also check your battery for low water.
Its possible.
Old Apr 4, 2002 | 11:25 PM
Amur_'s Avatar
Refined Valley Dude
No no no no no. It's not the charging system. Leave your battery alone.
I was through this two summers ago. The contacts inside the headlight switch are wearing down. Soon your headlights will stop responding as things deteriorate further. You can either pull the switch and open it up and try to either replace the contacts or beef them up (I've heard that the contacts can't be switched out and I don't know of anyone who's done it) or you can replace the switch. Go to a wreckers if you decide on replacing it - OEM will run you about $300!
It wouldn't hurt to also check the harness that goes from the switch to the CPU - ya never know.
ttyl,
Amur_
Old Apr 4, 2002 | 11:36 PM
tmak26b's Avatar
I see one of my contact in the headlight switch plug burned up. I kinda stuck a screwdriver to clean that part, i also spary the thing with electrical cleaner. WOnder if it will help. I will find out tomorrow. I dont think it is a loose battery because other lights work
Old Apr 4, 2002 | 11:44 PM
Amur_'s Avatar
Refined Valley Dude
Consider opening the switch. The surge that cooked the plug may have done damage inside the switch...
ttyl,
Amur_
Old Apr 4, 2002 | 11:46 PM
Bambam7's Avatar
I came, I saw, I boosted.
Headlight switch going is almost as common as the windshield wiper switch that doesn't switch the windshield wipers!
Find a switch, or try and clean up the contacts. IF you clean it- PUT DIELECTRIC GREASE ON THEM AFTER! It will prevent further corrosion.
This goes for wiper switch fixes too. It'll make the fix last years instead of months.
Old Apr 5, 2002 | 12:24 AM
SonicRaT's Avatar
Super Raterhater
My wipers still work, however I suffer the dieing light switch, my headlights work all the time, but my interior lights just go out on me every once in a while. Were your burn marks right at the switch?
Queppa
Nov 18, 2024 03:47 AM
Rotospectre
Mar 28, 2018 03:33 PM
Microtech
30
Apr 23, 2016 06:37 PM
fastsaab
Aug 19, 2015 11:42 AM
gtcd
30
Aug 19, 2015 02:44 AM
