Help! Wheel sizes
Old Aug 14, 2007 | 11:05 PM
speedbuddy7's Avatar
Help! Wheel sizes
Does anyone know if a 245/40 ZR18 profile and wheel size fit on a gen 2? any help would be appreciated
Old Aug 14, 2007 | 11:21 PM
RETed's Avatar
Too tight up front, IMO...
No problem in the rear, as long as width / offset is close.
-Ted
Old Aug 14, 2007 | 11:26 PM
do u think it will rub in the front or just stick out or the fender a bit
Old Aug 14, 2007 | 11:28 PM
Michael Knight's Avatar
Don't hassle the Hoff!
offset?
Old Aug 14, 2007 | 11:30 PM
42mm
Old Aug 14, 2007 | 11:53 PM
RETed's Avatar
Not going to fit up front with stock suspension.
7.0", +42 is too tight with that tire size.
7.5", +42 will hit the inside strut.
8.0", +42 will hit the inside strut.
8.5", +42 will hit the inside strut.
9.0", +42 will hit the inside strut.
Well, you get the picture...
_Ted
Old Aug 14, 2007 | 11:59 PM
ahh yeah kinda wat i was thinking, thanks for the help guys
Old Aug 15, 2007 | 12:01 AM
if i was gunna get 18s what would be a good offset and tire profile to look for
Old Aug 15, 2007 | 12:29 AM
RETed's Avatar
18" x 8.0", +30 would be ideal.
You can run a 225 or 235 wide tire on there.
Those kinds of offsets and widths are not easy to find.
-Ted
Old Aug 15, 2007 | 12:47 AM
thank you very much for the help ill start looking, would it be easier to find those offsets in a 17in wheel or about the same
Old Aug 15, 2007 | 12:54 AM
FCKing1995's Avatar
Rotary Slave
My 225/55/16's rub in the front and drag around sharp corners. So Id guess a 245/40/18 would as well.
ChrisRX8PR
Aug 21, 2015 01:56 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
