what can i do to minimize wheel hope
Old Aug 14, 2007 | 09:40 PM
moonless's Avatar
I've tried every clutch release technique there is and multiple rpm's for launching my car. Under 3000 it bogs over 3500 just wants to spin and hop. I'm running 1" eibach lowering springs all around and koni adjustable shocks only on the rear with factory fronts. my rim/tires are 17" rims with falken's 24540R17.
I'm wondering if the stiff ness of the suspension and limited side wall flex is the problem and if investing in a set of 15 inch rims and drag slicks would eleveate the hop.
Old Aug 14, 2007 | 09:48 PM
Eggie's Avatar
Have you tried adjusting the Konis?
Old Aug 17, 2007 | 09:42 PM
moonless's Avatar
not yet affraid to take much stiffness out of them they didn't really need compressed all that much to put the top cap on the spring affraid they will start to float like the factory shocks did was the whole reason i bought them in the first place just a cheap quick fix till i get the money for a full coilover set up
Old Aug 17, 2007 | 09:52 PM
Black91n/a's Avatar
No, try going stiffer.
Old Aug 19, 2007 | 10:30 AM
moonless's Avatar
their full stiff right now I cant go any stiffer at least not with them.
Old Aug 19, 2007 | 02:09 PM
Black91n/a's Avatar
Try replacing all the drivetrain mounts with stiffer or solid ones, same for the subframe and rear control arms. Wheel hop happens at least partly becuase of felxibility in the drivetrain and suspension.
Old Aug 19, 2007 | 06:32 PM
moonless's Avatar
cool looks like another thing 4 the to-do list this winter was going to change them all out to poly and delirium mounts last winter but sold the parts to my brotherinlaw since his car was tore apart for it at the time.
Th0m4s
Feb 26, 2019 02:04 AM
Snoopy FD
Dec 8, 2015 01:45 PM
Leeroy_25
Aug 17, 2015 12:53 PM
