Megasquirt Dumping fuel when tapping throttle
Old Aug 14, 2007 | 10:37 AM
AlexG13B's Avatar
brap brap brap
you know when you tap throttle to get car to move from a complete stop? whenever i do this the car just dumps fuel (u can see the black smoke out exhaust) AFRs drop to low 10s. i have tried changing numbers on the fuel map but nothing. Is there something else that controls this such as "ACCELERATION WIZARD"?
Old Aug 14, 2007 | 01:51 PM
muythaibxr's Avatar
MegaSquirt Mod
The accel wizard and the VE table together will cause/prevent this condition.
Ken
Old Aug 14, 2007 | 06:23 PM
quasar's Avatar
I'm in rotary heaven!
So how do you set the accel enrichments? I'm having a similar problem, but i'm not getting enough fule. As soon as i touch the throttle it wants to die with a load on it.
without a load on it it will rev but dies at idle.
Old Aug 15, 2007 | 09:20 AM
muythaibxr's Avatar
MegaSquirt Mod
Check out the section on accel enrichment tuning on www.megasquirt.info in the ms1 section. That'll give a much better explanation of it than I could.
Ken
Old Aug 15, 2007 | 04:12 PM
quasar's Avatar
Are you talking about tuning under the meganamual link? All i see is all the links under megamanual and tuning with megasquirt 2. I have read the megamanual front to back. Maybe my code variant is messed up but i still cant find the accell table.
Old Aug 16, 2007 | 09:26 AM
muythaibxr's Avatar
MegaSquirt Mod
http://www.megamanual.com/v22manual/mtune.htm#accel
That's the exact link. I'm not sure why you can't find the Accel tuning screen... it's labled "Accel Wizard" I believe, although I'll check it when I get home.
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
Skeese
65
Mar 28, 2017 03:30 PM
