Megasquirt Building PNP adapter for MS1 ver2.2(Help with conections)
Old Aug 13, 2007 | 12:39 PM
joeylyrech's Avatar
87 SE WITH S5 T2 SWAP
Question Building PNP adapter for MS1 ver2.2(Help with conections)
Okay im building a PNP adapter for my 2.2 MS and i need a little help with the conections,this its what i have done so far
DB 37 ECU PLUG
Injector bank one(primaries)33 and 32 3C and 3A
Injector bank two(secondaries) 34and 35 3H and 3H
power 28 31
PMW idle 30 2Q
TPS signal 22 2G
O2 signal 23 2D
IAT signal 20 2L
+5Vref 26 2A
IGt-T 29 1X
IGt-L 25 1V
IGs-T 27 IU
The ones that i need help with are the 2VR sensors,i dont know were to conect them on the ECU plug,1M on the ECU plug its suposed to be coil igniter trailing
but dont know were it goes on the DB37,also have i wire on pin 37 for the FPR and i dont know were it goes on the ecu plug,Thanks Joey
Old Aug 13, 2007 | 03:11 PM
monkhommey's Avatar
is it a S5 or S4? i am building a pnp adapter for an S5 NA right now so i have s5 ecu pinouts. im at work right now so i cant offer much help. but when i get home i will look into it more.
Old Aug 13, 2007 | 03:12 PM
monkhommey's Avatar
s5 turbo maybe?
Old Aug 13, 2007 | 03:55 PM
joeylyrech's Avatar
S5 turbo block,NA S4 harness with FD tps,stock coolant and air temp sensors
Old Aug 13, 2007 | 07:19 PM
monkhommey's Avatar
ok hear goes. i have a v.3 so i dont know much about the v2.2 but hopefully this helps.
for the CAS and the 2 vr circuits.
this diagram tells you the ecu pinouts to connect it to.
ok for 1M. its not used. this is vor v3 and i assume its the same for v2.2
as for the fpr i looked at the pinouts for the s4 ecu and couldnt find anything so i cant help you there. ill ask my brother, he has a s4 and might know.
if you have any problems understanding the diagrams then ill help explain it to you. you can also find these in the megasquirt FAQ section. good luck!
Old Aug 13, 2007 | 07:41 PM
joeylyrech's Avatar
okay i connected IGs-t to pin 1U,IGt-L to pin 1V and IGt-t to pin 1X,i guess im done with that,for the VR sensors i connected VR(G) red wire(+) to 1N and black wire to 1P,VR(NE) red wire(+) to 1R and black wire to 1Q,im not really good with wire diagrams but im trying hard,thanks for all the info buddy
cewrx7r1
15
Aug 6, 2018 11:41 AM
windom
Sep 11, 2015 04:48 AM
