Super AFC Area is for discussing the Apexi Super AFC
Super AFC Help UNWIRING SAFC
Old Aug 11, 2007 | 06:20 PM
RotaryBred's Avatar
Lost You in the Rear View
Help UNWIRING SAFC
Strangely enough, the FD i just aquired has BOTH a power FC and SAFC.. i wanna remove the SAFC but I do not know how to unwire the damn thing and no one will tune it until it's removed. I also believe having the double EMS is screwing up my AFR and my car is running like crap now.
Old Aug 15, 2007 | 06:28 PM
RotaMan99's Avatar
Before unhooking it, I would zero out your PFC. Removing the SAFC could also be adding or removing fuel and if it is, any corrections on the PFC could screw the engine up more.
The SAFC is simple to remove. There should be only ONE wire that is cut and that is the AFM wire. Find 2 wires from the SAFC that connect to 2 seporate wires and are NOT SPLICED. You should see that the 2 wires from the SAFC will connect to the same wire except one half is at the ECU plug and one half is from the harness. Both halfs should be the same color as well.
I wish I had a wiring diagram but I don't.
All other wires from the SAFC should only be spliced and not redirected. If ya know what I mean.
Old Aug 17, 2007 | 02:06 PM
RotaryBred's Avatar
SAFC has been removed... thanks :-) but unfortunately the problem with my car has not vanished. it actually had gone away for 2 days until i unhooked the SAFC. i tried hooking it back up to see if the problem went away but it made no difference. so lost
Old Aug 17, 2007 | 08:01 PM
RotaMan99's Avatar
Describe your problem a little more. When does the AFR change? How far does it change?
SaabGuy
19
Feb 4, 2004 08:25 PM
SaabGuy
Apr 21, 2002 07:16 AM
crossbar17
11
Apr 1, 2002 09:20 AM
Gefunk
Nov 15, 2001 09:36 PM
