FD brakes on an FC
Old Aug 10, 2007 | 03:18 PM
1986 RX-7's Avatar
FD brakes on an FC
i was just woundering if you could put FD brakes on an FC car please let me know what you think or know for that matter
Old Aug 10, 2007 | 04:41 PM
RacerXtreme7's Avatar
NASA geek
same calipers, there just smoother, rotors wont work. NO BENEFIT AT ALL unless you prefer smooth caliper over the FC rib look. Both are aluminum and both have same piston bore size (they even use the same brake pads).
~Mike..........
Old Aug 11, 2007 | 02:49 PM
1986 RX-7's Avatar
no moreso looking for the rotor i have the five lug
Old Aug 11, 2007 | 03:17 PM
Black91n/a's Avatar
No, doesn't fit, the offset on the rotors is all wrong.
Corksport sells a kit to put FD rears on the FC (may be 99+ rears), but that's counterproductive unless you've got much bigger fronts.
Do a search next time, it's been covered 43854764 times.
Old Aug 11, 2007 | 11:08 PM
RETed's Avatar
Why?
Are you having a braking problem?
Or just you wanna shop off your Mad TitE Big Brakes Y0!
-Ted
Old Aug 16, 2007 | 09:20 PM
1986 RX-7's Avatar
no I can't find any BIG BRAKE KITS for the FC just the FD
Old Aug 16, 2007 | 11:18 PM
Black91n/a's Avatar
Then you're not looking hard enough. A number of the forum sponsors sell kits, but the question remains, why? Are you having braking problems? If so do some maintenance on the system and it'll almost certainly fix the issue. The stock brakes are more than enough for road racing unless you've got tons of power.
Tem120
Sep 7, 2015 09:53 AM
Frisky Arab
Sep 4, 2015 06:17 PM
