brake issues
Old Aug 9, 2007 | 10:23 AM
silverbulletrt02's Avatar
Dreams bigger than wallet
brake issues
I've recently purched an 86 rx-7 and it has the 4 piston brakes on the front. on the passenger front caliper, 1 of the pistons is seized. the other 3 go in fine. I can't get the brake line off the caliper to try compressing the piston a little easier. any suggestions on either?!?
Old Aug 9, 2007 | 10:43 AM
aznpoopy's Avatar
strike up the paean
why can't you get the brake line off?
sounds like it needs a rebuild pretty badly
Old Aug 9, 2007 | 10:48 AM
the nut is pretty rounded off. i'm going to try a little bit of heat from a propane torch and maybe some vice grips.
Old Aug 9, 2007 | 11:05 AM
aznpoopy's Avatar
strike up the paean
file down the nut so it has two parallel flat sides and then use a channel lock
Old Aug 9, 2007 | 11:31 AM
ah, i'll give that a try as well. thanks!
Old Aug 14, 2007 | 02:01 PM
Okay, got teh caliper off, but the piston is still frozen.
also, i can't get the rotors off. I took the set screws out, but beyond that, i have no ideas why those damn things won't come off!!!
diabolical1
30
Jan 30, 2016 05:50 AM
rotor_veux
Sep 3, 2015 07:10 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
Marty RE
Aug 17, 2015 09:36 AM
