emission test problem...
Old Apr 3, 2002 | 10:20 PM
juliuspoa's Avatar
Newbie
Hi, I have hks dragger exhaust system on my '94 RX 7. I went to e-check and they couldn't have the reading on the exhaust. Anybody knows why? I've never had anything like this when I used the stock exhaust. Please help !!!
Old Apr 4, 2002 | 01:11 AM
rynberg's Avatar
I couldn't quite understand what your problem was (English, ************, do you speak it ), but whatever it was, it wasn't related to your HKS cat-back. Adding a cat-back exhaust has absolutely no effect on your emissions.
Old Apr 4, 2002 | 07:21 AM
djantlive's Avatar
The tail pipe sniffer can't get a reading? that's odd.
A lot of older smog machines can't detect the right RPM. Maybe that's the problem your mechanic experienced.
Just try another shop that has a different smog machine. Sun smog machines usually work better than Allen smog machines. Just make sure that they don't charge you if they can't smog you.
Old Apr 4, 2002 | 10:39 AM
neo_omega's Avatar
***Moderator***
are yoou sure there is no leak on your exhaust? Did you forget to plug the air pump back?
RedBaronII
Sep 20, 2015 11:29 AM
Mps_hell
Sep 19, 2015 10:02 PM
ZacMan
Sep 19, 2015 09:20 PM
localized
Sep 15, 2015 08:23 PM
