How are my compression numbers?
Old Apr 3, 2002 | 08:43 PM
waltk88's Avatar
I've put about 1300 miles on a street ported, 3mm apex seal motor. It idles very poorly and is extremely difficult to warm start, both symptoms of a bad compression motor. I did a compression test today and got 100psi for the front rotor and 87psi for the rear. I don't have a strong reference as to what's good and what's bad for rotary compression. Based on these numbers, how healthy is my motor?
Old Apr 3, 2002 | 09:19 PM
P'cola FD's Avatar
Hamado things my way!
Ouch. 85 psi is the limit. your engine is right there at the limit. I would defineatly talk to your engine's builders. I hope you broke it in properly.
Old Apr 3, 2002 | 09:27 PM
luneytune's Avatar
Re: How are my compression numbers?
Should be six numbers? min psi is 100 at 250rpm plugs removed from both rotors. Can't use a regular compression meter either, must be a graphing type (Mazda). Biggest difference between rotor chambers is 21psi.
ZacMan
Sep 19, 2015 09:20 PM
SCinfidel
Sep 8, 2015 05:36 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
