PFS PMC Area for discussing the Peter Farrell Supercars PMC/PMS.
PFS PMC *Peter Farrell PMS users* Read...
Old Apr 3, 2002 | 08:34 PM
93 R1's Avatar
I just bought one of these and I'm just wondering how good this thing really is?
What mods are you guys running with it?
Are you running any other electronics with it (avc-r)?
Any dyno figures or timeslips?
Opinions?
Old Apr 3, 2002 | 08:45 PM
Crashunit's Avatar
MIA
I have it and mine came with a manual type boost controler, but I dont have the PMS controller with it. Tripoint dyno tuned my car with it and I havent had any problems. I'd show you my dyno sheet but its an emmisions dyno and not a Jet dyno, so my readings are all wack... I'll have my car dynoed soon tho, once I get it back. Oh yeah, I basically have every bolt-on on my car, with 99 jspec turbos.
Old Apr 3, 2002 | 09:07 PM
Johnny's Avatar
OG
I used it for about 1 year..
All the bolts ons...I now run all the bolts on minus MP and use the PFC. You can get just as much power out if it...I switch mainly due to drivability...I had some bad 3k hes that the PFC eliminated.
I never dynoed with it...but I do have 115mph trap speeds...w/ MP...whatever kind of power that translates too
Old Apr 3, 2002 | 09:18 PM
slipperyslater1's Avatar
I've had mine for a couple of weeks now and i'm happy with it so far. I'm running DP, CB, Opened factory airbox. This is what it is tuned for, right off the bat. I keep it in the low setting most of the time, to keep boost stock. I change to middle setting occasionally. Getting ready to see how it does with mid-pipe or high flo cat. Afraid to really mess with it myself, will let shop tune it. Its easy to seriously screw yourself, so be careful. Good luck.
Old Apr 3, 2002 | 10:49 PM
ronarndt's Avatar
PFS PMS
check sig for mods. Mainly satisfied, except for random max boost fuel cut-off. Have not found a real fix for that problem.
Old Apr 4, 2002 | 12:13 AM
Crashunit's Avatar
MIA
i get a boost cut too sometimes like above 5500 rpm when I floor it, I thought it might have been a loose hose... you guys get that too?? So could it be the PMS rather then that?
Old Apr 4, 2002 | 07:30 AM
93 R1's Avatar
Are you guys running a boost controler too?
Wouldn't this control spikes and prevent you from hitting fuel cut?
Old Apr 4, 2002 | 02:50 PM
93 R1's Avatar
Old Apr 4, 2002 | 02:58 PM
Coulthard Fan's Avatar
Originally posted by 93 R1
Are you guys running a boost controler too? Wouldn't this control spikes and prevent you from hitting fuel cut?
You don't need any other electronics with it since it controlls the boost.
You can still get boost spikes with an open exhaust because the stock wastegate on the twin turbos can't vent off all the boost you are making - you would need to port the wastegate to fix this... which is why I still run a main cat. As for hitting fuel cut, I think the PMS tricks the ECU into not triggering the fuel cut.
I like my PMS, it was installed and tuned by PFS and I never have had a single problem. If you find someone local to help you tune it for your car that will probably make your life a little easier.
My engine mods are: PFS PMS, PFS Intercooler and intake, Efini Y-pipe, Pettit Pully, PFS downpipe, Apexi Dual N-1 catback, and 99 twin turbos... it goes without saying that the car really moves
Old Apr 4, 2002 | 04:04 PM
93 R1's Avatar
What kind of times are you guys running with the PMS?
Old Apr 4, 2002 | 04:10 PM
Call 911's Avatar
Check sig
396 RWHP @ 6400 rpm
Should be around 430 @ 7500 with some tuning.
Also im using AVC-R, which I spliced right in the PMS harness.
I do have a stumble around 3200-3300 rpms (right before the secondary inj. come on) under light load, that I cant work out.
Im hoping to get the AEM(haha) or Haltech soon!
Old Apr 4, 2002 | 04:14 PM
Call 911's Avatar
Dont like talking about them
Old Apr 4, 2002 | 04:22 PM
sbrx7's Avatar
Hey guy,
I have all the bolt on's, DP/MP/CB, Pettit intake, M2 Medium IC, PFS PMS obviously, RP fuel pump, RP drag lauch kit, M2/GAB Coilovers. The only problems I've had with my unit was listening to conventional list wisdom. "Add fuel" everyone tells me. Car runs like crap for months before I finally break down and take it to a dyno. Turns out I'm running waaaayyyy rich. Three hours of careful tuning on the dyno and I'm making 320 RWHP@14 psi. All this on an 85K mile engine. Moral of the story, go to the dyno and see what your car wants to run right. Maybe lots of fuel, maybe not. Oh yeah, my engine did just die last night, water seals gave it up at 94K miles. I drove the car hard for 40K miles with varying degrees of modifications and I'm not upset at the failure.
Steve Bertok
94 MB touring
12.32@111 mph (before the IC upgrade!)
Old Apr 4, 2002 | 04:27 PM
sbrx7's Avatar
.....oh yeah. All of this with no spikes, no creeps, no ported wastegates or any other craziness. Never even changed a pill in the wastegate lines. Why does it work like that? I dunno. Maybe I just got lucky and got a really good car. Maybe my piecemeal modifications worked well together.
Go figure.
Steve
Old Apr 4, 2002 | 04:52 PM
93TTRX7's Avatar
Go figure.
Steve
Sucks you blew your motor man! I'm gonna get my car done at Rotary Power for 1) Reliability...and 2) Power. I'm gonna try something different and try to build the coolest running RX-7, see if that helps reliability. Since Rotary Power doesn't tune computers, I'll take it to SP Engineering probably and have them do it...they charge a lot but I hope I wont have to see them often if they can get it done right. Lots of people speak poorly of XS engineering that is why I am hesitant to go there.
Old Apr 4, 2002 | 08:20 PM
93 R1's Avatar
UNVMY7:
What are you using to control the 1200's?
Peter told me the PMS wasn't capable of this.
sbrx7:
Sweet times. Sorry about the motor. Good luck
Old Apr 4, 2002 | 08:42 PM
Call 911's Avatar
Thats interesting. Well its working just fine. I dont understand why it wouldn't.
Maybe he was talking about the preset maps not being capable of, which come tuned for the 850cc ? Did he go into any detail?
Old Apr 4, 2002 | 09:16 PM
LUV94RX7's Avatar
Oldie, but Goodie
Originally posted by 93 R1 UNVMY7:
What are you using to control the 1200's?Peter told me the PMS wasn't capable of this.
Dave at KDR is programming my PFS PMS with 1200cc secondaries, No problem. But it can't handle the 1600cc ones.
Ken
Old Apr 4, 2002 | 09:57 PM
93 R1's Avatar
Sweet at ****.
I thought that I wasn't going to be able to use this thing for very long due to fuel requirements,
but if you are running T78 and 1200's on it I'll be fine as long as its properly tuned (wideband).
Thanks alot!
Old Apr 4, 2002 | 09:59 PM
93 R1's Avatar
Typo: SWEET AS ****!
Old Apr 4, 2002 | 10:01 PM
twinturborx7pete's Avatar
Juris Doctor
ya i have one too... just haven't found many people using them.. i guess there are.. i still haven't installed mine as i'm afraid to mess things up... i found some maps from Dave Black online because i'm pretty much running the same mods as him.. so i would think that the maps should do me right.. we'll see!
Old Apr 5, 2002 | 05:53 AM
silver93's Avatar
check out wade's site for lots of good info:
http://www.wvinter.net/~flanham/wlanham/
The unit is pretty easy to learn to navigate, not as bad as some might think. a wideband REALLY helps alot.
either rent one or get on a dyno or something -
Old Apr 5, 2002 | 09:17 AM
the_saint's Avatar
Talking
Very happy with mine.
Still stumbles at 3k, but I can live with that.
Have not dynoed mine, but I am faster than my friends Viper GTS.
thesaint
Old Apr 5, 2002 | 10:15 AM
UNVMY7:
93 R1 - here is my understanding of this issue: it's not that the EFI box (which if you didn't know already is the well renowned unit the PFS box is based on, with Peter's base tuning added and some neat logos on the box and the controller) can't control 1200cc secondary injectors, it's that the stock ratio of primary to secondary injectors must be maintained, which IIRC is 550/850 (.647 to 1) Is this what others understand to be the limiting factor as well? Something about the fact that the PMS is a piggyback to the stock ECU?
Personally, I have no intention of upgrading my injectors based on my current mods[listed above somewhere]. 93 R1 - what engine mods are you running or do you intend to run that you think you need larger injectors? If you are not intending to go over 360 RWHP, you probably shouldn't be worring about this. (Sure, I've heard people say they got 400 RWHP on stock injectors but that seems to be the edge of the envelope which I'd never do on my street driven motor.)
Scott
p.s. as for the stumble... I've never had it. I'm not knocking anyone by saying this, but make sure your car is running 100% before you add the PMS. This will save you a ton of headaches later.
