Canadian Forum Canadian users, post event and club info here.
new problem
Old Aug 2, 2007 | 09:54 PM
rxwannabe's Avatar
new problem
just finished working the initial bugs out of my newly acquired 85 gsl and have encountered a new issue.
when the key is put into the ignition, it can only be turned with significant force cant be a good thing! any suggestions?!
thanks folks!
Old Aug 3, 2007 | 08:05 AM
pfsantos's Avatar
(blank)
Steering lock interfering? Wiggle the steering wheel as you turn the switch. Other than that, some lubrication may help. Can't be much else IMHO.
Old Aug 6, 2007 | 09:09 PM
rxwannabe's Avatar
igniton
doesnt seem to be steering lock ... and junior just broke his key off trying to get the igniton to turn.
any other suggestions? is this the kind of work a general mechanic/garage could tackle?
any ideas what a new igniton column would be worth?
Old Aug 6, 2007 | 09:33 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
try lubricating the lock.
if that fails, bring it to a locksmith.
it will be much cheaper then buying a new steering column, which you probably don't need.
Old Aug 6, 2007 | 10:51 PM
Alak's Avatar
It would either be related to the locking mechanism or steering lock itself, and not the ignition switch. The accual ignition switch is just a plastic peice that turns easily.
I would lubricate. If all else fails, a cant imagine a mechanic not being able to diagnose the problem at the very least.
Old Aug 7, 2007 | 11:59 AM
Feds's Avatar
More Mazdas than Sense
Spray some jigaloo, or any graphite lubricant in there. While you're at it, hit the door locks and the hinges too.
WyomingTII
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
