Megasquirt Q4 Replacement with TIP120 for BACV control
Old Aug 1, 2007 | 04:13 PM
Jobro's Avatar
SAE Junkie
Has anyone done this? I bought a TIP120 because diyautotune.com sold them, they didn't have the one maui recommended to use. Will this do the job?
Old Aug 1, 2007 | 04:45 PM
quasar's Avatar
I'm in rotary heaven!
I'm blocked off but I'm almoste sure you dont need that mod kit. Megasquirt pcb3 should already have a function to contole the bypass valve. Maybe someone else can help more with the diagram and wiring though.
Old Aug 1, 2007 | 05:14 PM
renns's Avatar
The TIP120 should work just fine. I'm running one of the TIP series as well, not sure of the number though.
Old Aug 1, 2007 | 09:35 PM
toplessFC3Sman's Avatar
Yea, i used the DIY autotune kit for the BAC and it works fine.
Old Aug 2, 2007 | 10:58 AM
muythaibxr's Avatar
MegaSquirt Mod
TIP 120 will work fine.
I used the ztx689 transistor because it fit where the old transistor did with no wires.
Ken
Old Aug 2, 2007 | 05:02 PM
Jobro's Avatar
SAE Junkie
Thanks to everyone that posted!
I don't mind using the Q16 place for Q4
fjwheeler
22
Jan 9, 2022 01:02 PM
