Whats that noise??
Old Apr 3, 2002 | 12:30 AM
crankit's Avatar
Whats that noise??
Got this nosie coming from the rear end or maybe driveshaft. It clunks after I put the clutch in then change gears. Like coming up to a stop put the clutch in shift to different gear and hear a clunk in the rear end when I shift. Also have a rattle noise maybe ujoints but not quite sure what to listen for. They do have a little play in the ujoints but its been doing this noise for over a year. If its in the rearend itself would I hear it very clearly.??
Old Apr 3, 2002 | 06:28 AM
Rotor13B's Avatar
Wassup!!
Sounds like a u-joint to me, or could be your pinion and ring gear backlashing, but that would give your car a shudder when you take off if the teeth were badly worn. And yes you'll be able to hear it pretty clear.
Old Apr 3, 2002 | 07:50 AM
85RX7GS's Avatar
Mine does the same 'clunk' especially when going into 5th gear, because I hold the clutch in longer since it is such a longer throw. Since mine is an 85, do you think it's the driveshaft?
Old Apr 3, 2002 | 09:36 AM
yayarx7's Avatar
Are you Nucking Futs?
sounds like the driveshaft U-joints to me.
gxl90rx7
Haltech Forum
Jun 30, 2017 11:30 PM
Linda_Lovelace
Sep 18, 2015 10:04 PM
zxrazorxz
Sep 14, 2015 07:21 PM
