Help with splicing radiator hose
Old Apr 3, 2002 | 01:14 AM
juliof's Avatar
Put the temp sender at the thermostat housing, inline with the thermostat see Robs site
Old Apr 3, 2002 | 09:32 AM
Import Convert's Avatar
Well, you could always use the plug in the side of that housing, but you will probably have to remove your air pump for it to fit in there.
Old Apr 3, 2002 | 09:38 AM
djantlive's Avatar
Never heard of splicing the rad hose. I don't think it's a good idea... Rob's site says punching a hole in the thermo housing, not splicing the hose. Where do you hear about this splicing the hose idea? Your idea?
Old Apr 3, 2002 | 10:48 AM
Lost Time's Avatar
Chimera Driver
By splicing into a rad hose you are going to have inaccurate readings. The reason they place the sender on the thermo housing is that will give you the most accurate readings, as coolant comes out fo the motor headed for the radiator. If memory serves, I believe you use a 1/4" NPT to tap into the housing, then you thread in the sender. That's for the mech gauge. If you have the electrical, you may need a smaller tap, the instructions should say. All in all it took maybe two hours to do it, including bringing the housing to a machine shop and letting them tap it (DO NOT try to tap an NPT fitting into aluminum unless you know what you are doing).
Old Apr 3, 2002 | 06:23 PM
A-Spec's Avatar
here's one made by trust. I think you can easily fabricate your own. Get a steel tube and weld the fitting for the temp sensor on there.
David
Old Apr 3, 2002 | 06:27 PM
Lost Time's Avatar
Chimera Driver
You sure Trust makes that, it says GReddy on it.
