FD Wheel Fitment
Old Jul 26, 2007 | 01:41 PM
rx7girlTK's Avatar
FD Wheel Fitment
Ok I searched but I couldn't find what I was looking for.
What tires can I run with:
Front-18x9 +34 offset
Rear-18x10 +42 offset
I have Tein S Tech Springs so it is dropped 1.42 in the front and 1.3 in the rear.
Will I have to roll the fenders?
Old Jul 26, 2007 | 06:59 PM
7racer's Avatar
The front rim won't fit with that offset. Check out the Jimlab sticky at the top of this subforum
Old Jul 26, 2007 | 09:00 PM
rx7girlTK's Avatar
I was told by Mackin that it would.
Old Jul 26, 2007 | 09:57 PM
7racer's Avatar
here is my thread when I was working out the wheel fitment for my car
https://www.rx7club.com/forum/showthread.php?t=389749
I ended up running
255/35/18 in the front
275/35/18 in the back
Old Jul 26, 2007 | 10:59 PM
SpeedKing's Avatar
Power Trippin'
Of course they'll tell you that, they're trying to make a sale!
Like "7Racer" said, that front offset won't work - it's too low. For a 9" wide wheel up front, I'd recommend a +44 or higher.
Old Jul 27, 2007 | 12:23 AM
apex_sideway's Avatar
FD dream is dead
For that offset to work you'll have to get a pretty hefty fender roll and up front you'll probably have to run a 245 series tire. Worse case scenario is you need coil-overs.
Check out posts started by plaguepunx where he uses 17x9+22 up front with a 235 series tire. You can make the low offset work but what you have to do to make it work might not be the best thing for handling and a daily driven car (However, Plaguepunx car looks BADASS!) Also, there's another guy running 17x10+35 rims with 255's on all four corners with the same springs as you ----> https://www.rx7club.com/suspension-wheels-tires-brakes-20/5zigen-fn01-rcs-fd-621010/page4/
Old Jul 27, 2007 | 06:50 AM
turbogarrett's Avatar
0 lbs of boost
It will work with a drifter tire size, heavily rolled fender or possibly a little negative camber.
Old Jul 27, 2007 | 08:44 AM
rx7girlTK's Avatar
Thanks guys!
Old Jul 27, 2007 | 09:01 AM
ptrhahn's Avatar
For whatever reason, the Japanese wheel makers always list offsets in the mid 30's for the FD, and I'm not sure what they're smoking.
It's been proven time and time again in the real world that offsets like that mean lunch time on your fender lips. For a 9" wheel, think 40 or higher... and you'll still do yourself a favor by getting the fenders rolled.
Good luck!
Old Jul 27, 2007 | 09:33 AM
rx7girlTK's Avatar
I'm going to change them to +41.
Question about fender rolling. Will the paint chip?
Old Jul 27, 2007 | 09:40 AM
ptrhahn's Avatar
It shouldn't if done right. A heat gun should be used to soften the paint. Find a good body shop that does custom work.
Old Jul 27, 2007 | 09:44 AM
Mahjik's Avatar
Mr. Links
That's to give you an idea of what to expect. That's Tein S-Techs with 17x9 +43 in the front (255 size tire). I definitely had to roll the fenders (which IMO, you should anyways when going with aftermarket rims).
Old Jul 28, 2007 | 12:08 AM
SpeedKing's Avatar
Power Trippin'
What wheels are you getting? Do they come in any higher offsets?
Old Jul 28, 2007 | 08:59 AM
rx7girlTK's Avatar
I'm going to run +34 235/40/18 maybe 225/40/18 and roll the fenders.
I don't want to hear about the fitment it's what I want.
Old Jul 28, 2007 | 06:08 PM
jimlab's Avatar
Super Snuggles
Good for you. Listening to people who know what they're talking about is boring and predictable.
Old Jul 28, 2007 | 09:22 PM
rx7girlTK's Avatar
I meant I don't want to hear about stretching the tire.
Old Jul 28, 2007 | 11:15 PM
7syawedis's Avatar
do it. make it fit if thats what you want. im sick of wheel fitment sissys!! i have a 17x9+17 up front right now. try a 35 series tire with 18s.
235s look fine on a 9, 225s thats not even much of a stretch. roll it. might have to yank the fender liners thats the only place i ever had trouble, but at my height even the stockers rubbed.
but you shouldnt go too nuts if you have to ask about fitment. tire size is a big part, if you run smaller tires low offsets are not an issue at all. 215 and 235 40 series is what i use. thats how. with 18s try a 35 series.
Old Jul 29, 2007 | 01:54 AM
jimlab's Avatar
Super Snuggles
Originally Posted by 7syawedis
i have a 17x9+17 up front right now. try a 35 series tire with 18s. 235s look fine on a 9, 225s thats not even much of a stretch.
I'll bet that looks absolutely fabulous. Positively drifterific, even.
Old Jul 29, 2007 | 03:52 AM
goreify's Avatar
40k worth of fail
No worries, with a roll that can be done easily.
Like was said before, check out plaguepunx car. he runs 17x9 +22, He's got a 5mm spacer on there now too because it wasn't enough for him!
I believe hes at 235/40 up front but dont quote me on that.
Old Jul 29, 2007 | 10:45 AM
7racer's Avatar
Do you have a link to a thread that he has with pictures of his setup?
Old Aug 2, 2007 | 02:47 AM
goreify's Avatar
40k worth of fail
Here ya go:
https://www.rx7club.com/suspension-wheels-tires-brakes-20/new-wheels-work-vskfs-578543/
Old Aug 2, 2007 | 03:31 AM
plaguepunx's Avatar
yup just a roll and 235 and no it does not "lunch" my tires either.
Old Aug 2, 2007 | 12:15 PM
jimlab's Avatar
Super Snuggles
Still looks like ****, and it negatively impacts performance.
Just say you're doing it for appearance only and be done with it. Don't try to sell some bullshit like "it's proper fitment for me". Proper fitment is not subjective.
Old Aug 2, 2007 | 12:48 PM
7racer's Avatar
HA! I remember that thread. His idea of "fitting" was running negative camber. With all of those comments on his thread I am surprised that you wanted to re-reference it.
On the road and on the track, the FD can act a little squirrelly with that much camber.
But whatever floats your boat.
Old Aug 2, 2007 | 12:51 PM
7racer's Avatar
also...
this guy in the post below yours
https://www.rx7club.com/forum/showthread.php?t=674309
has 18x9 +44 running 265/35/18
and had to CUT his fender lip!!!
Why on earth wouldn't you just get proper fitting wheels so you don't have to deal with this crap anyways! The FD has enough gremlins. Why create more.
