Starter?
Old Apr 2, 2002 | 09:47 AM
Starter?
Hey guys I just purchased a 90 TII and I have a question.
This has happend to me twice already, I would try to start the car and it will just keep turning over like 4 or 5 times then I stop and try again and it would start like normal.
Any ideas whats wrong?
Old Apr 2, 2002 | 10:49 AM
Samps's Avatar
Maybe a slight flooding problem. Does the car send any codes?
Old Apr 2, 2002 | 10:57 AM
Im not exactly sure what you mean. What codes should I be looking for.
I also have a problem with the idiot lights some times they all come on then go away.
Old Apr 2, 2002 | 12:21 PM
Samps's Avatar
You probably have some faulty wiring. The codes I'm referring to are the codes that the car sends when something is wrong. To check them you need to ground the lil green one prong plug that is located just in front of your leading coil (the one by the battery). Just take a piece of wire and shove it in the plug then ground the wire. Now turn the car to the "on" position and watch for the check engine light to blink. The number of times it blinks is a code. You need to count the blinks; one blink then pause then three quick blinks is a bad pressure sensor for instance. Then it will repeat itself or show a different code. The coresponding problems to go with the codes are somewhere on this forum, can't remember where. But if you check for codes then come back and post; someone will help ya out.
Old Apr 2, 2002 | 09:21 PM
Thanks Samps, ill check it out when I get time tomorrow maybe.
LongDuck
Oct 7, 2015 08:12 PM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
Devon Murray
Sep 25, 2015 09:41 AM
