EGT #'s for NA?
Old Apr 1, 2002 | 10:23 PM
jon88se's Avatar
Eat, sleep, work, mod.
EGT #'s for NA?
okay, got I'm takin an EGT gauge from the shop (not sure if I'll go w/ Greddy or HKS) so I can know the real effects of tunin my AFM. So, what numbers should I look for in terms of a powerful but safe mixture on an 88 NA with all the goods (sans a port job). Also, what is the optimal position to mount the sensor??
Old Apr 1, 2002 | 11:31 PM
Scott 89t2's Avatar
SOLD THE RX-7!
your best bet is to hook the EGT up as well as a wide band o2, and when the 02 readings are good, those are the egt's you want... you can't just take somebody elses egt #'s and asume they are right for you. many things change them. bet I'd asume somewhere around 800-900C. I think the N/As are hotter then turbos.
Old Apr 2, 2002 | 12:45 AM
RETed's Avatar
Where is the probe gonna be placed?
-Ted
Old Apr 2, 2002 | 12:50 AM
Ryde _Or_Die's Avatar
Don't you want it as close to the exhaust manifold as possible(or where the manifold used to be with a header)?
Old Apr 2, 2002 | 01:00 AM
RETed's Avatar
Yep, but most people put them in the "downpipe" (mid-pipe for your NA guys)...
There's a BIG difference in temps between the two positions.
-Ted
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
immanuel__7
Megasquirt Forum
Aug 22, 2015 09:34 PM
