Will this fit on a FC
Old Jul 13, 2007 | 11:04 AM
kyle_94538's Avatar
Hi all,
Will 17x8 with 235-40-17 & 17x9 with 255-40-17 & 38 offset all around fit an FC? I think that 235 in the front will rub, but may be wrong. Thanks!
Old Jul 13, 2007 | 11:48 AM
RETed's Avatar
Fronts will fit if you run aftermarket coilovers that give you added clearance.
Else, with stock type suspensions, it's going to hit.
At least a 1/4" spacer is needed to get you enough clearance on the insides in this case.
-Ted
cewrx7r1
15
Aug 6, 2018 11:41 AM
BLK 93
11
Sep 9, 2015 10:56 AM
