how do you pass emissions.
Old Jul 10, 2007 | 06:39 PM
Pnoidrummer's Avatar
in CA.... apparently you cant swap a TII engine into an NA shell. is this true? and if so, anyone know how to bypass it w/o making the car a non-op or race only or off road only vehicle?
Old Jul 10, 2007 | 06:58 PM
gross polluter's Avatar
It's legal once you get it approved by a smog referee.
http://www.arb.ca.gov/msprog/aftermkt/replace.htm
Engine Changes
Engine changes are legal as long as the following requirements are met to ensure that the change does not increase pollution from the vehicle:
The engine must be the same year or newer than the vehicle.
The engine must be from the same type of vehicle (passenger car, light-duty truck, heavy-duty truck, etc.) based on gross vehicle weight.
If the vehicle is a California certified vehicle then the engine must also be a California certified engine.
All emissions control equipment must remain on the installed engine.
After an engine change, vehicles must first be inspected by a state referee station. The vehicle will be inspected to ensure that all the equipment required is in place, and vehicle will be emissions tested subject to the specifications of the installed engine.
Old Jul 13, 2007 | 10:54 AM
thanks =D that really helped
JP's 93 fd
Sep 16, 2015 01:12 PM
