another intercooler q.
Old Jul 9, 2007 | 11:53 PM
wackaloo13's Avatar
is a 18x16x4 core overkill for 500hp? how big is to big?
Old Jul 10, 2007 | 08:04 AM
scrip7's Avatar
Rotary Gearhead
I'm not sure how many guys on here are using a 4" thick core, or even if it will fit without too many mods. I would be curious how much pressure drop there would be on a core that size. Perhaps someone who uses that big of a core will chime in.
Old Jul 10, 2007 | 03:45 PM
wackaloo13's Avatar
i have the space for it, im tilting the radiator back a bit and im going to put it in diagonally in the space between the radiator and the round bar. It will defenitely fit, im just concerned about hte pressure drop
Old Jul 10, 2007 | 04:02 PM
classicauto's Avatar
Crash Auto?Fix Auto.
Thats not very big.
In an ideal airflw scenario, I'd say 500whp is the limit of that I/C.
Thickness is not always greater then surface area. A 3" thick core with a 24"X 16" cross section will cool better then that.
Also, pressure drop has alot to do with endtank design. More so then the size of the core alone.
Old Jul 10, 2007 | 04:42 PM
mort2002's Avatar
the greddy/trust 3 row is 4" thick. i have one in my car, and it fit just fine.
Old Jul 10, 2007 | 06:03 PM
Evil Aviator's Avatar
Rotorhead
It's not overkill, but you could probably use a smaller intercooler if you would like. It's difficult to say though, since the construction makes a big difference in performance. You can read about most of the factors here:
http://www.are.com.au/feat/techtalk/intecoolersMR.htm
how big is to big?
If you are extremely particular about response, then you want the smallest intercooler possible so as to reduce lag. Otherwise, an intercooler that is "too big" would not fit in the engine bay, so you don't really need to worry about that.
If pressure drop is a huge concern, then you would probably be better off with a horizontal-mount with direct-feed end tanks. Each 90deg tubing bend will incur about 0.15 to 0.4psi pressure drop in an average application. Also, you may want to choose an intercooler brand that publishes its pressure drop statistics rather than hoping that the nice sweat-shop folks did a good job making your cheapie E-bay intercooler.
ls1swap
Jun 3, 2024 03:25 PM
1NSIGHT
Sep 25, 2015 12:59 PM
MILOS7
Sep 18, 2015 03:39 PM
Devon300zx
Sep 17, 2015 03:50 PM
