Megasquirt VE 1 table questions.
Old Jul 4, 2007 | 11:56 AM
quasar's Avatar
I'm in rotary heaven!
So my car runs but the whole table is making it run rich. I was wondering if insted of changing each value one at a time there is a wizzard that will help me lean out the whole table? I aquired the map from a guy on msefi.com and his configuration is close to what i have but i have smaller injectors. He had 800 primary and 1100 secondarys, I have 550 primary and 720 secondarys.
Old Jul 4, 2007 | 12:23 PM
quasar's Avatar
I found a table wizzard and used it but I'm guessing I dont know how to use it. It left me with a table full of 0's and also had a max of 100 kpa. Looked like something set up for a N/A engine. It also set my required fuel to 21.1. I reset everything back to my last saved msq file so i'm back to my origonal problem. I need to read and better understand what i'm doing with all of this before I continue.
Old Jul 4, 2007 | 01:05 PM
renns's Avatar
You could change the req_fuel value, or using Tools->Table Transform->Scale option. Be sure to set your scaling factor correctly, as your injector spread is different than the original.
Old Jul 4, 2007 | 04:04 PM
quasar's Avatar
I got it to idle, now I have to work with the rest.
http://youtube.com/watch?v=9nSucS6XaH8
Coochas
44
Nov 5, 2019 11:08 PM
Microtech
Nov 21, 2015 10:20 AM
edgars95rx7
Link Vi-PEC
Oct 1, 2015 01:59 PM
befarrer
Sep 22, 2015 09:33 AM
