What's The Problem??
Old Mar 31, 2002 | 07:10 PM
BoOsTin FD's Avatar
Powered by** Rotary
Well again the same problem. I checked the injectors all 4, I took them to be cleaned they are all in working condition. I checked spark plugs, wires, coil and fuel filter. Everything works fine.
However, I still get the same hesitation around 2k to 3500k. It's as if it wants to stop but then it pulls. Only happens at those rpm's. After 3500k or before 2k it pulls fine.
It irritates me when it feels like I’m pressing the break at high Rpm's.
Does anyone know what the problem is?? If you do Please post it how to fix the damn thing.
Thanks
Old Mar 31, 2002 | 08:50 PM
BoOsTin FD's Avatar
Powered by** Rotary
Come on guys, someone must have had same problem?
Old Mar 31, 2002 | 10:04 PM
did you check your wires, and grounds?
Old Apr 1, 2002 | 09:21 AM
BoOsTin FD's Avatar
Powered by** Rotary
Yeah i checked wires and grounds. I grounded boost pressure sensor and tps extra, still the same.
Old Apr 1, 2002 | 09:28 AM
Josepi's Avatar
Despise Enmity
Check TPS for resistance, set it correctly. Play with the plunger to make sure you are getting a smooth transition from 1.0v to 5.0v .
Just my 2¢
Old Apr 1, 2002 | 11:42 AM
Icemark's Avatar
Yeah I am thinking TPS or primary injectors are not working correctly
WyomingTII
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
